2021 Honda CRF150R [Model Overview]
The 2021 CRF150R is for Future Champions​
Honda Motorcycles has released the 2021 CRF150R and it is available in both standard or big wheel (Expert) sizing. The Expert version of this Japanese motorcycle is geared towards taller riders, offering larger wheels, seat height, and suspension travel.
The CRF150R is Honda’s smallest motocrosser in the 2021 Honda lineup but it still comes with the performance features of the larger motocross bikes such as Showa suspension that is comprised of 37mm inverted forks and a single Showa shock in the rear. It comes powered by a 149cc liquid-cooled four-stroke Unicam engine. The CRF150R’s engine delivers a smooth torque throughout the rev range giving the rider exactly the power they need when they need it.
It is the perfect bike for junior motocrossers looking to upgrade their ride to match their skills. It’s powerful, well balanced, and maintains Honda’s known reliability.
The 2021 Honda CRF150R starts at $5,399 USD / $6,449 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Honda CRF150R in one place.
2021 Honda CRF150R
  • Price: $5,399 USD / $6,449 CAD
    • Fuel Injection
    • Disc brakes front and rear
    • Electric starter
    • Inverted Forks
Main Specs​
  • Engine: 149cc liquid-cooled, single-cylinder, four-stroke
  • Power: 23.47 horsepower
  • Wet Weight: 186 lbs (84.4 kg)
  • Seat Height: 866 mm (34.1 in.) at the lowest point
Competitors​
2021 Honda CRF150R
2021 Honda CRF150R Specifications​
Engine149cc liquid-cooled single cylinder four stroke
Power23.47 horsepower
Bore x Stroke66mm x 43.7mm
Compression Ratio11.7:1
Fuel SystemKeihin 32mm flat slide with Throttle Position Sensor (TPS)
Valve TrainUnicam®, four-valve; 26mm intake, steel; 22.5mm exhaust, steel
Clutch
TransmissionClose-ratio five speed
Final Drive#420 chain; 15T/50T
Suspension Front37mm fully adjustable leading-axle inverted Showa® cartridge fork; 10.8 inches of travel
Suspension RearPro-Link® fully adjustable Showa single shock; 10.7 inches of travel
Brakes FrontSingle 220mm disc
Brakes RearSingle 190mm disc
Tires Front70/100-17 Dunlop MX51
Tires Rear90/100-14 Dunlop MX51
Fuel Tank Capacity2.0 gallons
ColorRed
IgnitionSolid-state CD with electronic advance
Headlight
Tail Light
Overall Length
Overall Width
Trail3.1 inches
Wheelbase49.6 inches
Ground Clearance11.9 inches
Seat Height32.8 inches
Curb Weight185 pounds (Includes all standard equipment, required fluids and full tank of fuel–ready to ride.)
Warranty
2021 Honda CRF150R
2021 Honda CRF150R Features​
UNICAM® ENGINE​
The CRF150R uses a Unicam engine based on our championship-winning CRF450R. Designed to give you excellent rideability and more power and torque across the rev range, the engine runs consistently at different tracks—it’s an all-around winner.
PERFORMANCE​
ACCELERATOR PUMP
The CRF150R uses a carburetor featuring a “direct push” accelerator pump which gives you better, more immediate throttle response.
HANDLING​
TRACK-DESIGNED CHASSIS
A lightweight, high-tensile steel frame with large-diameter frame tubing and crossmember delivers excellent turning performance and straight-line tracking.
PRO-LINK® REAR SUSPENSION
The CRF150R’s Pro-Link® rear-suspension system features a fully adjustable Showa® shock for superb bump absorption and wheel control.
SHOWA® SUSPENSION
The adjustable 37mm leading-axle inverted Showa® cartridge fork features specially tuned valving for small bumps and a friction-reducing design to improve compression and rebound control.
ENGINEERING​
FRONT DISC BRAKE
The front disc brake provides powerful, precise braking.
LIGHTWEIGHT WHEELS
Strong, lightweight wheels are durable and minimize unsprung weight.
REAR DISC BRAKE
The rear disc brake provides powerful, precise braking.
STYLE​
BIG-BIKE MX GRAPHICS
The CRF150R features clean, bold, bright graphics that look like our CRF450R’s. Look like a pro, ride like a pro.
2021 Honda CRF150R Photos​
2021 Honda CRF150R
2021 Honda CRF150R
2021 Honda CRF150R
2021 Honda CRF150R
2021 Honda CRF150R Videos​
Honda Websites​
Other Links​
The post 2021 Honda CRF150R [Model Overview] appeared first on webBikeWorld.
