2021 Honda CRF250R [Model Overview]
The 2021 CRF250R Is Ready for the Championship​
Honda Motorcycles’ CRF250R has seen a multitude of off-road competitions over the past few years. These places consist of AMA Arenacross and the other is the AMA Supercross series. Being involved in competitive events such as these is a true testament to the quality, durability, and reliance of the CRF250R model.
This Japanese motorcycle is something that is seen on podiums in Supercross races and it comes from its power, stability, and low center of gravity. The power is delivered from its liquid-cooled DOHC fuel-injected engine with smooth power delivery. Its nimbleness comes from the twin-spar aluminum chassis finished with the same detail found on factory bikes found in the 2021 Honda lineup.
The only thing the 2021 CRF250R needs for it to have a podium is the right rider – that’s where you come into the mix. Hop on, ride and take advantage of what the CRF250R offers you. It maintains the look and feels of a championship dirtbike – that’s because it is.
The 2021 Honda CRF250R starts at $7,999 USD / $9,799 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Honda CRF250R in one place.
2021 Honda CRF250R
  • Price: $7,999 USD / $9,799 CAD
    • Fuel Injection
    • Disc brakes front and rear
    • Electric starter
    • Inverted Forks
Main Specs​
  • Engine: 249cc liquid-cooled, single-cylinder, four-stroke
  • Power: 39 horsepower
  • Wet Weight: 238 lbs (108 kg)
  • Seat Height: 957 mm (37.7 in.) at the lowest point
Competitors​
2021 Honda CRF250R
2021 Honda CRF250R Specifications​
Engine249cc air-cooled single-cylinder four-stroke
Power39 horsepower
Bore x Stroke71.0mm x 63.0mm
Compression Ratio9.6:1
Fuel SystemFuel-injection, 34mm throttle bore
Valve TrainSOHC; four-valve
Clutch
TransmissionFive-speed
Final Drive#520 O-ring-sealed chain; 13T/50T
Suspension Front41mm telescopic fork; 8.5 inches of travel
Suspension RearPro-Link® Showa single shock with spring-preload adjustability; 9.0 inches of travel
Brakes Front240mm disc
Brakes Rear220mm disc
Tires Front80/100-21
Tires Rear100/100-18
Fuel Tank Capacity1.6 gallons
ColorRed
IgnitionFull Transistorized
Headlight
Tail Light
Overall Length
Overall Width
Trail102mm
Wheelbase55.9 inches
Ground Clearance11.3 inches
Seat Height34.8 inches
Curb Weight265 pounds (Includes all standard equipment, required fluids and a full tank of fuel-ready to ride)
WarrantyUnlimited-mileage, limited warranty
2021 Honda CRF250R
2021 Honda CRF250R Features​
ENGINEERING​
SINGLE-CYLINDER ENGINE
A single is the perfect choice for a bike like the CRF250F. It’s light, simple, fuel-efficient, and features plenty of power and torque in all areas, along with smooth power delivery—ideal for a wide range of rider experience.
CLEAN-RUNNING ENGINE
Another benefit of fitting the CRF250F with fuel injection? Now it even meets California’s stringent CARB emissions standards for off-road motorcycles—good news for everyone.
FUEL INJECTION
Fuel injection means the CRF250F starts right up, even in cold weather. Compared to a carbureted bike, it also helps reduce emissions and enhance performance and fuel efficiency. And say goodbye to clogged pilot jets when you put this bike away for storage.
PETAL-DISC FRONT BRAKE
Check out that front brake rotor—the petal-disc design is right off the competitive MX circuit. It’s light, runs cooler, and also helps reduce unsprung weight.
REAR DISC BRAKE
Drum brake in the rear? Not the CRF250F. We gave it a disc rear, just like the front. You get crisp, balanced, powerful braking at both ends.
HANDLING​
STRONG, LIGHT TWIN-SPAR FRAME
The CRF250F gets a tubular-steel twin-spar frame that’s both light and tough.
18-INCH REAR WHEEL
A 21-inch front and 18-inch rear wheel give you a wide selection of tire choices for trail riding.
21-INCH FRONT WHEEL
PRO-LINK® REAR SUSPENSION
Thanks to our single-shock Pro-Link® rear suspension and Showa® damper, the CRF250F delivers excellent comfort, traction and handling, while also improving rider confidence. The rear suspension features 9.0 inches of travel.
SHOWA® FORK
The telescopic Showa® fork features large 41mm sliders. That makes it strong and helps add to the CRF250F’s excellent handling.
CONVENIENCE​
ELECTRIC STARTER
Turn the key, push the button, and let’s go riding! Electric starting is a big help on cold mornings, or if you need to restart out on the trail. Honda’s proven system makes riding just that much more fun.
COMFORT​
COMFORTABLE SEAT POSITION
With a long, motocross-style seat, you can move forward and back, left and right with ease, helping you navigate changing terrain in comfort.
COUNTERBALANCED ENGINE
Because it features a counterbalancer, the CRF250F’s engine is a smooth runner. You get the narrow overall width and power advantages of a single along with the smoothness of a multi-cylinder bike.
STYLE​
MX STYLING
Honda’s CRF450R and CRF250R are two of the hottest motocross bikes on the circuit. And they’re some of the coolest looking. We gave the CRF250F plenty of that racing DNA when it comes to style. This is one bike you’ll be proud to ride!
2021 Honda CRF250R Photos​
2021 Honda CRF250R
2021 Honda CRF250R
2021 Honda CRF250R
2021 Honda CRF250R
2021 Honda CRF250R Videos​
Honda Websites​
Other Links​
The post 2021 Honda CRF250R [Model Overview] appeared first on webBikeWorld.
