The 2021 Kawasaki Ninja 1000SX: Team Greens Tanto Sword
The 2021 Kawasaki Ninja 1000SX remains at the top of the Ninja Sport series from Team Green, carrying forward for 2021 largely unchanged. After getting suspension revisions between the 2019 and 2020 model years, this Japanese-made Sport Touring machine is a wonderful ride.
The 1,043cc 16-valve in-line four is silky smooth with a melodious exhaust note from all 138 horsepower. Similar to the other top offerings of the 2021 Kawasaki lineup, the Ninja 1000 has an advanced IMU providing all the latest electronic riding wizardry. Owners will now enjoy the latest in Kawasaki Cornering Management, Traction Control, Selectable Rider modes, Up and Down Quick Shifting, and Improved ABS. Connect the Kawasaki Rideology app to your smartphone and new ride tracking features open up, also connecting phone functions to the color TFT display.
Colors for 2021 include — Metallic Carbon Gray / Metallic Diablo Black, Metallic Moondust Gray / Metallic Diablo Black.
The 2021 Kawasaki Ninja 1000SX starts at $12,599 USD / $14,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Ninja 1000SX in one place.
- Price: $12,599 USD / $14,999 CAD
- ABS Brakes
- Smartphone Connectivity
- Assist And Slipper Clutch
- Twin LED headlights
- Engine: 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
- Power: 104.5kW (142hp)@10,000 RPM
- Torque: 81.9 lb-ft (111 NM) @ 8,000 RPM
- Wet Weight: 233 kg (514 lb)
- Seat Height: 820 mm (32.3 in)
- BMW R 1250 RS
- Suzuki Katana
- Yamaha Tracer 9 GT
2021 Kawasaki Ninja 1000SX Specifications
Engine | 1,043cc, 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled |
Power | 104.5kW (142hp)@10,000 RPM |
Bore x Stroke | 77.0 x 56.0mm |
Compression Ratio | 11.8:1 |
Fuel System | DFI® w/38mm Keihin throttle bodies (4) and oval sub-throttles |
Lubrication | |
Clutch | |
Transmission | 6-speed, return shift |
Final Drive | Sealed chain |
Suspension Front | 41mm inverted cartridge fork with stepless compression and rebound damping, adjustable spring preload/4.7 in |
Suspension Rear | Horizontal back-link with stepless rebound damping, remotely adjustable spring preload/5.7 in |
Brakes Front | Dual 300mm petal-type rotors with radial-mount 4-piston monobloc calipers and ABS |
Brakes Rear | Single 250mm petal-type rotor with single-piston caliper and ABS |
Tires Front | 120/70 ZR17 |
Tires Rear | 190/50 ZR17 |
Fuel Tank Capacity | 5.0 gal |
Color | Metallic Carbon Gray/Metallic Diablo Black |
Ignition | TCBI with digital advance |
Headlight | LED |
Tail Light | LED |
Overall Length | 82.7 in |
Overall Width | 32.5 in |
Overall Height | 46.9 / 48.2 in |
Wheelbase | 56.7 in |
Ground Clearance | 5.3 in |
Seat Height | 32.3 in |
Curb Weight | 513.8 lb |
Warranty | 12 months |
Kawasaki Protection Plus | 12 / 24 / 36 / 48 months |
2021 Kawasaki Ninja 1000SX Features
Assist & Slipper Clutch
Economical Riding Indicator
Electronic Cruise Control
Electronic Cruise Control allows a desired speed (engine rpm) to be maintained with the simple press of a button. Once activated, the rider does not have to constantly apply the throttle. This reduces stress on the right hand when traveling long distances, enabling relaxed cruising and contributing to a high level of riding comfort.Electronic Throttle Valves
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
KCMF (Kawasaki Cornering Management Function)
Using the latest evolution of Kawasaki’s advanced modeling software and feedback from a compact IMU (Inertial Measurement Unit) that gives an even clearer real-time picture of chassis orientation, KCMF monitors engine and chassis parameters throughout the corner – from entry, through the apex, to corner exit – modulating brake force and engine power to facilitate smooth transition from acceleration to braking and back again, and to assist riders in tracing their intended line through the corner. The systems that KCMF oversees vary by model, but may include:• S-KTRC/KTRC (including traction management and wheel lift management)
• KLCM (including traction management and wheel lift management)
– Designed to optimize acceleration from a stop
• KIBS (including pitching management and corner braking management)
• Kawasaki Engine Brake Control
POWER MODES
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.Smartphone Connectivity
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.2021 Kawasaki Ninja 1000SX Photos
2021 Kawasaki Ninja 1000SX Videos
Kawasaki Official Websites
The post 2021 Kawasaki Ninja 1000SX [Model Overview] appeared first on webBikeWorld.
