2021 Kawasaki Ninja H2 and H2 Carbon [Model Overview]
When too much is just right: The 2021 Kawasaki Ninja H2 and H2 Carbon​
There is absolutely no point in trying to explain why anyone needs so much power, but Kawasaki fully understands, we just do. Thankfully we have this Japanese-made, alien-styled supersport street beast to fill this instinctual biker need.
Powered by a Supercharged, 998cc, liquid-cooled, 4-stroke DOHC 16-valve In-line four-cylinder engine, making 228.0 HP (166.4 kW) @ 11500 RPM, and 141.7 Nm (104.9 ft.lbs) @ 11000 RPM of torque. This is flat-out bonkers Kawasaki, and I love it. Available in a standard version, and a Carbon version, the differences truly come down to exclusivity.
There is no weight or performance advantage to the Carbon model, but you do get a full carbon fiber cowl like the H2R, special silver-mirror paint with a matte element, and individual numbering, with a serial number stamped on the supercharger plate. This is the highest performance model, legal on the street, in the 2021 Kawasaki lineup.
Kawasaki has always been a manufacturer that meant business when it came to performance. The Ninja lineup has had turbochargers in the past, but when introduced in 2015 with a supercharger, it was clear Kawasaki was looking to deliver the king of the streets. This is not a moto GP machine with mirrors and turn signals, the H2 is meant to scare the PC crowd, and keep you screaming like a madman under your visor with every twist of the wrist.
The 2021 Kawasaki Ninja H2 and H2 Carbon starts at $29,500 USD / $33,000 CAD and $33,000 USD / $37,000 CAD, respectively.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Ninja H2 and H2 Carbon in one place.
  • Price: $29,500 USD / $33,000 CAD (H2) – $33,000 USD / $37,000 CAD (H2 Carbon)
    • Kawasaki Cornering Management Function (KCMF)
    • Kawasaki Traction Control (KTRC)
    • Kawasaki Launch Control Mode (KLCM)
    • Kawasaki Intelligent Anti-lock Brake System (KIBS)
    • Kawasaki Engine Brake Control
    • Kawasaki Quick Shifter (KQS) (upshift & downshift)
    • Öhlins Electronic Steering Damper
Main Specs​
  • Engine: 998cc Liquid -cooled, 4-stroke, In-Line Four, DOHC, 16-valve
  • Power: 228.0 HP (166.4 kW) @ 11500 RPM
  • Torque: 141.7 Nm (104.9 ft.lbs) @ 11000 RPM
  • Wet Weight: 524.8 lbs (238.1 kg)
  • Seat Height: 32.5 inches (825.5 mm) at lowest point
Competitors​
2021 Kawasaki Ninja H2 and H2 Carbon Specifications​
Engine998 cc, Liquid -cooled, 4-stroke, In-Line Four, DOHC, 16-valve
Power228 Hp
Bore x Stroke76.0 x 55.0mm
Compression Ratio
8.5:1
Fuel SystemDFI® with 50mm throttle bodies (4) with dual injection ; Kawasaki Supercharger
Maximum Torque104.9 lb-ft @ 11,000 rpm
Clutch
Transmission6-speed, return, dog-ring
Final DriveSealed chain
Suspension Front43mm inverted fork with adjustable rebound and compression damping, spring preload adjustability and top-out springs/4.7 in
Suspension RearUni-Trak®, Öhlins TTX36 gas charged shock with piggyback reservoir, 22-way compression and rebound damping and adjustability and hand-turn spring preload adjustability, and top-outspring/5.3 in
Brakes FrontDual radial-mount, opposed 4-piston Brembo Stylema® calipers, dual semi-floating 330mm discs, KIBS ABS
Brakes Rear
Opposed 2-piston calipers, single 250mm disc, KIBS ABS
Tires Front120/70 ZR17 (58W)
Tires Rear200/55 ZR17 (78W)
Fuel Tank Capacity4.5 gal
Color
Mirror Coated Black
IgnitionDigital
HeadlightLED
Overall Length82.1 in
Overall Width30.3 in
Overall Height44.3 in
Wheelbase57.3 in
Ground Clearance5.1 in
Seat Height32.5 in
Curb Weight524.8 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus
(optional)
12, 24, 36 or 48 months
2021 Kawasaki Ninja H2 and H2 Carbon Features​
Assist & Slipper Clutch​
Economical Riding Indicator​
Electronic Throttle Valves​
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.
Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
Kawasaki Engine Brake Control​
The Kawasaki Engine Brake Control system allows riders to select the amount of engine braking they prefer. When the system is activated, the engine braking effect is reduced, providing less interference when riding on the track.
KLCM (Kawasaki Launch Control Mode)​
Designed to assist riders by optimizing acceleration from a stop, KLCM electronically manages engine output to minimize wheel spin when moving off. With the clutch lever pulled in and the system activated, engine speed is limited to a determined speed while the rider holds the throttle open. Once the rider releases the clutch lever to engage the clutch, engine speed is allowed to increase, but power is regulated to minimize wheel spin and help keep the front wheel on the ground. The system disengages automatically once a predetermined speed has been reached, or when the rider shifts into third gear. Depending on the model, riders can choose from multiple modes, each offering a progressively greater level of intrusion.
KCMF (Kawasaki Cornering Management Function)​
Using the latest evolution of Kawasaki’s advanced modeling software and feedback from a compact IMU (Inertial Measurement Unit) that gives an even clearer real-time picture of chassis orientation, KCMF monitors engine and chassis parameters throughout the corner – from entry, through the apex, to corner exit – modulating brake force and engine power to facilitate smooth transition from acceleration to braking and back again, and to assist riders in tracing their intended line through the corner. The systems that KCMF oversees vary by model, but may include:
• S-KTRC/KTRC (including traction management and wheel lift management)
• KLCM (including traction management and wheel lift management)
– Designed to optimize acceleration from a stop
• KIBS (including pitching management and corner braking management)
Smartphone Connectivity​
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.
Supercharged Engine​
Drawing on the know-how and technology possessed by the Kawasaki Heavy Industries, Ltd. (KHI), Kawasaki’s supercharged engine delivers high engine output while maintaining a compact design. The key to achieving this incredible performance lies in the engine’s supercharger – a motorcycle-specific unit designed completely in-house with technology from the Kawasaki Gas Turbine & Machinery Company, Aerospace Company and Corporate Technology Division.
One of the greatest benefits of designing the supercharger in-house and tailoring its design to match the engine’s characteristics was that engineers were able to achieve high-efficiency operation over a wide range of conditions – something that would not have been possible by simply dropping in or trying to adapt an aftermarket automotive supercharger.
The importance of high efficiency in a supercharger is that, as the air is compressed, power-robbing heat gain is minimal. And while many superchargers are able to offer high-efficiency operation in a very limited range of conditions, the Kawasaki supercharger offers high efficiency over a wide range of pressure ratios and flow rates – meaning over a wide range of engine speeds and vehicle speeds. This wide range of efficient operation (similar to having a wide power band) easily translates to strong acceleration. The supercharger’s high efficiency and minimal heat gain also meant that an intercooler was unnecessary, greatly saving weight and space, and enabling the engine’s compact design.
2021 Kawasaki Ninja H2 and H2 Carbon Photos​
2021 Kawasaki Ninja H2 and H2 Carbon Videos​
Kawasaki Official Websites​
The post 2021 Kawasaki Ninja H2 and H2 Carbon [Model Overview] appeared first on webBikeWorld.
