2021 Kawasaki Versys-X 300 [Model Overview]
The 2021 Kawasaki Versys-X 300: A Small Adventurer For City Fun​
The Versys-X 300 is Kawasaki’s smallest adventure motorcycle in the 2021 lineup, designed mostly for city roads and maybe some gravel and dirt alleyways. More accurately an adventure tourer than an out-and-out adventure bike, and partially because most of Japan’s roads are paved, the Versys-X 300 is nonetheless a capable commuter and adventure motorcycle. Powered by a 296cc DOHC liquid cooled parallel twin, the Versys-X 300 produces 40 HP and 19 lb-ft of torque. While that may not sound like much, the entire bike weighs only 386 lbs wet.
Borrowing heavily from its larger engined brethren, the Versys-X 300 features a low seat height paired with a high front cowling and windshield. This is to both keep the rider as close to the center of balance on the bike, as well as to help the airflow coming off the windshield to fly over the helmet of the rider, reducing buffeting and wind noise. Optional handguards help keep your hands warm, and the Kawasaki-designed quick mount system is installed on the rear, allowing for your own pannier lockers, saddlebags, or Kawasaki hard luggage system to be installed.
The 2021 Kawasaki Versys-X 300 starts at $5,899 USD / $6,799 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Versys-X 300 in one place.
  • Price: $5,899 USD / $6,799 CAD
    • Windscreen and front high cowl
    • Dual-zone ABS
    • Add-on options are extensive, from handguards to engine protectors
Main Specs​
  • Engine Type: 296cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin
  • Horsepower: 40 HP
  • Torque: 19 lb-ft
  • Wet Weight: 386 lbs (175 kg)
  • Seat Height: 32.1 inches (815 mm)
Competitors​
2021 Kawasaki Versys-X 300 Specifications​
Engine296cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin
Power40 hp
Bore x Stroke62.0 x 49.0mm
Compression Ratio
10.6:1
Fuel SystemDFI® with 32mm throttle bodies (2)
Lubrication
Clutch
Transmission6-speed, return shift
Final DriveSealed chain
Suspension FrontTelescopic fork/5.1 in
Suspension RearUni-Trak® swingarm/5.8 in
Brakes FrontSingle disc, ABS
Brakes Rear
Single disc, ABS
Tires Front100/90-19M/C 57S
Tires Rear130/80-17M/C 65S
Fuel Tank Capacity4.5 gal
Color
Metallic Graphite Gray/Metallic Spark Black
IgnitionTCBI with digital advance
HeadlightLED
Overall Length85.4 in
Overall Width33.9 in
Overall Height54.7 in
Wheelbase57.1 in
Ground Clearance7.1 in
Seat Height32.1 in
Curb Weight385.9 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2021 Kawasaki Versys-X 300 Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
ABS (Anti-lock Brake System)​
ERGO-FIT®​
Proper fit is key for rider comfort and control. However, the ideal fit varies from rider to rider, depending on their physical dimensions and riding style.
ERGO-FIT® is an interface system designed to allow riders to find their ideal riding position. Various points of the chassis interface (the handlebar, footpegs and seat, etc.) can be adjusted through a combination of interchangeable parts and parts with adjustable positions. This enables a wide range of riders to find a riding position that offers both comfort and control. Feeling at one with their machine, they will be able to experience how Kawasaki machines are fun and rewarding to ride.
*Adjustable parts and their range of adjustability vary by model.
2021 Kawasaki Versys-X 300 Photos​
2021 Kawasaki Versys-X 300 Videos​
N/A
Kawasaki Official Websites​
The post 2021 Kawasaki Versys-X 300 [Model Overview] appeared first on webBikeWorld.
