2021 Zero S [Model Overview]
2021 Zero S: EV Performance on a Budget​
The American-built Zero S is the perfect motorcycle for riders seeking a cheaper EV option for their daily commute. This motorcycle has more modest performance and range numbers, but what it will excel at is getting you from point A to point B while producing ‘zero’ emissions, making the world a better place for everyone.
This is the first official step down from the higher-end Zero motorcycles in their 2021 lineup that all feature 14.4 kWh batteries. The S model has half the battery capacity as its bigger brothers with a 7.2 kWh total capacity; meaning that you’re going to see approximately half the range and power numbers.
This EV motorcycle produces 46 horsepower with 78-lb-ft of torque and should get you a combined 68 miles before you fully deplete the battery.
Although the S misses out on some of the figures we see in the more expensive models, it still comes standard with Bosch’s Gen 9 ABS system and a set of grippy Pirelli Diablo Rosso II tires to stick your torque to the pavement in a safe manner. The ‘Minimalist’ LCD dash is shared with the SR and provides the rider with all information you may need on your ride: charge, power output, riding mode, charge time, etc. As with all models, the LCD also links up to your smartphone in the event you want to use it as a secondary dash or see detailed information about your ride.
The 2021 Zero S starts at $10,995 USD / $14,495 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Zero S in one place.
2021 Zero S
Motorcycle Overview​
  • Price: $10,995 USD / $14,495 CAD
    • Standard ABS
    • 98 MPH top speed
    • 7.2 kWh battery pack
    • Passively air-cooled permanent magnet AC motor
    • Five year unlimited mile power pack warranty
    • $0.81 average recharge cost
  • Engine: 7.2 kWh Battery
  • Power: 46 BHP
  • Torque: 78 lb-ft
  • Wet Weight: 313lbs (142 kg)
  • Seat Height: 31.8 inches (807 mm) at lowest point
2021 Zero S
2021 Zero S Specifications​
Engine
Peak torque
78 ft-lb (106 Nm)
Peak power
46 hp (34 kW) @ 4,300 rpm
Top speed (max)
98 mph (158 km/h)
Type
Z-Force® 75-5 passively air-cooled, high efficiency, radial flux, interior permanent magnet, brushless motor
ControllerHigh efficiency, 550 amp, 3-phase brushless controller with regenerative deceleration
Lubrication
Drivetrain
Clutch
Final Drive90T / 18T, Poly Chain® HTD® Carbon
belt
Chassis
Suspension FrontShowa 41 mm inverted cartridge forks, with adjustable spring preload, compression and rebound damping
Suspension RearShowa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound damping
Brakes Front
Bosch Gen 9 ABS, J-Juan asymmetric dual piston floating caliper, 320 x 5 mm disc
Brakes Rear
Bosch Gen 9 ABS, J-Juan single piston floating caliper, 240 x 4.5 mm disc
Tires FrontPirelli Diablo Rosso II 110/70-17
Tires Rear
Pirelli Diablo Rosso II 140/70-17
Fuel Tank CapacityN/A
Color
Power system
Power packZ-Force® Li-Ion intelligent integrated
Charger type1.3 kW, integrated
Charge time (standard)5.2 hours (100% charged) / 4.7 hours (95% charged)
Dimensions
Wheelbase
55.5 in (1,410 mm)
Overall Width
Trail3.2 in (80 mm)
Rake
24.0°
Seat Height31.8 in (807 mm)
Curb Weight
313 lb (142 kg)
Warranty
Warranty
2 years
2021 Zero S
2021 Zero S Features​
Pure Performance
Transform performance profiles with the press of a button to perfectly conquer city streets, urban arteries or twisty back roads. The Zero S is pre-programmed with Eco or Sport modes. Connect using your mobile device to customize performance or get stats on your ride.
Performance Profiles
Pure stealth. Propelled by the industry’s most advanced tech, the Z-Force® powertrain slingshots you forward. No shifting. All torque. Just smooth acceleration at the twist of a throttle. The Zero S strips away the noise, fumes and vibration so all you feel is the uninterrupted flow of the ride.
Charge up to 6x faster.
The Charge Tank option funnels up to 85 miles of riding into the Zero S for every hour of charging when plugged into a Level 2 charge station. One cup of coffee now equals ~30 miles of riding. Or, charge fully in as little as an hour depending on battery size.
Charging. Meet household outlet.
No special charging equipment required. Your standard household outlets just became “fueling” stations that deliver daily rides at a fraction of the cost of gasoline. Plug in at night and start every day with a full “tank.”
Ride more. Maintain less.
Goodbye costly powertrain maintenance and stale waiting room donuts. Sophisticated. Simple. The Z-Force® powertrain eliminates the greasy mess of fossil burners. No oil, spark plugs, clutches, filters, chain adjustments or expensive tune-ups. Instead, a carbon fiber belt directly connects the rear wheel to a motor that uses a single moving part to deliver torque at levels beyond conventional superbikes.
Always advancing. Code for the Z-Force® powertrain is constantly refined to deliver improved performance. The Zero App easily delivers the upgrades using your mobile device.
Longest Range Electric Motorcycle
The Zero SR is our farthest traveling model (and the longest-range production electric motorcycle on earth). At its core is the highest power and energy density battery in the EV industry. The higher the battery capacity, the more range.
Select the battery size that works for you. Ride over 200 miles city / 100 miles highway using the highest capacity Zero SR ZF14.4 battery coupled with the Power Tank accessory (adds an additional 3.6 kWh). Or, shed weight and gain storage space with the Zero S ZF7.2.
2021 Zero S Photos​
2021 Zero S
2021 Zero S
2021 Zero S
2021 Zero S
2021 Zero S Videos
Zero Motorcycles Websites
The post 2021 Zero S [Model Overview] appeared first on webBikeWorld.
