2022 Aprilia Tuono V4 & Tuono V4 Factory [Specs, Features, Photos]
2022 Aprilia Tuono V4 & Tuono V4 Factory: High Performance Ergonomics
In an attempt to make strapping yourself to an Italian superbike more comfortable, Aprilia offers what is essentially an RSV4 (their peak performance bike) retrofitted with a more upright seating position and better ergonomics for long-distance riding. The Aprilia Tuono is the perfect bike for riders that want to experience Aprilia’s legendary V4 engine with the added ability to enjoy long-distance riding that isn’t hampered by an uncomfortable seating position.
While the RSV4 is marketed as a violent track machine settled nicely in their 2022 lineup, the Tuono V4 is marketed as a violent track machine… With a few comfort quirks. The Tuono V4 shares many of the same components found on the RSV4 such as the same 65° liquid-cooled DOHC 1,077cc V4 mill de-tuned with a smaller bore to produce a much more manageable 175 horsepower and 89 lb-ft of torque through its six-speed transmission.
Although the Tuono V4 benefits from a more comfortable riding position when compared to the RSV4, it is still quite aggressive; but not aggressive enough that it makes city riding and long-distance riding a far-fetched dream.
The upright seating position paired with Cornering ABS, pit limiter, cruise control, various rider modes (for both on and off-track) make it a serious contender for riders seeking a machine similar to the RSV4 but with a more relaxed approach. Like the RSV4, many recent updates to the platform came in 2021 in the form of an updated swingarm and sturdier subframe for making passenger traveling a breeze.
If the standard Tuono V4 isn’t enough for you, Aprilia also offers a “Factory Edition” that brings an upgraded Brembo brake package and overhauls the suspension with an Öhlins NIX front fork and Öhlins TTX single shock absorber with piggy-back managed by Smart EC 2.0 electronics.
The 2022 Aprilia Tuono V4 starts at $15,999 USD / $19,499 CAD.
The 2022 Aprilia Tuono V4 Factory starts at $18,995 USD / $21,995 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Aprilia RSV4 & RSV4 Factory in one place.
  • Price: Starting at $15,999 USD / $19,499 CAD
    • Recently updated engine borrowed from the legendary RSV4
    • Three riding modes for the street, plus three for the track
    • Recently redesigned swingarm design based on MotoGP experience
    • A Factory addition with upgraded Brembo braking and Ohlins active suspension systems
Main Specs​
  • Engine: 1077cc 65-degree V4
  • Power: 175 HP
  • Torque: 89 lbs-ft
  • Wet Weight: 461 lb (209 kg)
  • Seat Height: 32.4 in (823 mm) at lowest point
Competitors​
2022 Aprilia Tuono V4 & Tuono V4 Factory Specifications​
Engine1077cc 65-degree V4
Engine Power175 HP
Bore x Stroke
Compression Ratio
Fuel System
Starter
Torque89 lbs-ft
Clutch
Transmission
Final Drive
Suspension Front
Suspension Rear
Brakes Front
Brakes Rear
Front Wheel
Rear Wheel
Fuel Tank Capacity
Color
Ignition
HeadlightLED
Tail Light
Overall Length
Overall Width
Saddle Height
Wheelbase
Ground Clearance
Seat Height32.4 in (823 mm) at lowest point
Wet Weight461 lb (209 kg)
Warranty
2022 Aprilia Tuono V4 & Tuono V4 Factory Features​
Setting the benchmark​
The Aprilia Tuono V4 continues to raise the bar in the Hypernaked category with never-before-seen levels of performance and sophistication, the result of Aprilia know-how and the unrivalled experience of the inventors of this class of bike. They took a superbike and created a vehicle that delivers sheer joy on the road and track alike. It’s little wonder it has been described as “the most extraordinary sports bike you can buy, with performance and finishes second to none”.
Absolute power, total control​
The Tuono V4 remains the only naked powered by the unique four-cylinder narrow 65° V engine. It may be Euro-5 compliant, but that hasn’t come at the cost of the inimitable sound and famed outstanding performance. With its 175 horsepower and 121 Nm, together with the dazzlingly balanced chassis and advanced electronics package, this extraordinary 1077-cc V4 is set to continue to dominate the entire Hypernaked category.
A new style​
The new style of the Tuono V4 is inspired by the RS 660, with its innovative double fairing with aerodynamic appendix function, characterised by reduced surfaces and the new triple LED light configuration with DRLs that include “bending lights”. The new design puts the focus on ergonomics with a revamped fuel tank shape and tail faring creating more space and a better fit for the rider.
The Aprilia Tuono V4 Factory and Tuono V4​
The Factory title is bestowed upon those Aprilia bikes that have proved their mettle on the track and comparative tests around the world. The Tuono V4 Factory continues to push the boundaries and forge ahead of rivals, new and old, that every year try to knock it off the top podium in the class invented by Aprilia.
The Tuono V4 is no slouch either in the speed department, but with new ergonomics and specially-designed accessories, it is the perfect companion for touring and adventures near and far.
Top electronics​
With six Riding Modes, three each for both road and track, riders simply need to select the preferred setting and parameters such as Traction Control, Wheelie Control, ABS and the engine brake will be automatically adjusted to deliver the mode selected.
Daytime Running Lights​
The fairing contains a triple front LED light combination with perimetral DRLs positioned around the two main headlights in an illuminated signature that makes the Tuono V4 instantly day or night.
A revolutionary chassis​
The already legendary chassis and incomparable riding experience are taken up another notch with the addition of a new, lightweight aluminium swingarm with a lower reinforcement brace. There’s no need to be patient while you get to know this bike, as it’s a case of instant bonding and trust as you execute perfect trajectories with confidence and ease.
2022 Aprilia Tuono V4 & Tuono V4 Factory Photos​
2022 Aprilia Tuono V4 & Tuono V4 Factory 2022 Aprilia Tuono V4 & Tuono V4 Factory 2022 Aprilia Tuono V4 & Tuono V4 Factory 2022 Aprilia Tuono V4 & Tuono V4 Factory
2022 Aprilia Tuono V4 & Tuono V4 Factory Videos​
Aprilia Tuono V4 Factory is still the super naked to beat | MCN review
Aprilia Official Websites​
The post 2022 Aprilia Tuono V4 & Tuono V4 Factory [Specs, Features, Photos] appeared first on webBikeWorld.
