2022 BMW G310GS Adventure [Specs, Features, Photos]
The 2022 BMW G310GS: Urban Adventure​
The smallest bike in the BMW Adventure category, the little GS is a fantastic urban adventure machine. BMW designs this machine in Europe and the manufacturing is done in India sharing the 313cc single-cylinder engine with a Roadster in the 2022 lineup. The solid engine can slice through urban landscapes with ease thanks to a solid 34hp.
Following the GS tradition, the riding position is more upright and the ergonomics are well sorted. The standard equipment list is very good with BMW Motorrad ABS, LED lighting, and a slick luggage rack.
3 Color choices for the 2022 BMW G310GS : Polar White, Style Rallye, Triple Black
The 2022 BMW G310GS starts at $5,695 USD / $6,795 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW G310GS and GS Adventure in one place.
  • Price: $5,695 USD / $6,795 CAD
    • BMW Motorrad ABS
    • Electric Ride by Wire throttle
    • Stainless steel exhaust system
    • LED headlight, turn indicators and rear light
    • Adjustable brake and clutch levers
    • Luggage carrier
Main Specs​
  • Engine: 313cc single-cylinder
  • Power: 34 hp at 9,250 rpm
  • Torque: 20 lbs-ft at 7,500 rpm
  • Wet Weight: 386 lbs (175 kg)
  • Seat Height: 32.8” (835 mm)
Competitors​
2022 BMW G310GS Adventure Specifications​
Engine313cc, Water-cooled, single-cylinder 4-stroke engine, four valves, two overhead camshafts and wet sump lubrication
Engine Power34 hp at 9,250 rpm
Bore x Stroke80 mm x 62.1 mm
Compression Ratio10.9 : 1
Fuel deliveryElectronic fuel injection
Max Torque20 lbs-ft at 7,500 rpm
ClutchMulti-disc oil bath (anti-hopping) with self-reinforcement
TransmissionConstant mesh 6-speed gearbox integrated in crankcase
DriveX-ring chain with shock absorption in the real wheel hub
Suspension FrontInverted fork, 41 mm
Suspension RearCast aluminum dual swing arm, central spring strut, spring pre-load adjustable
Brakes FrontSingle disc, diameter 11.8″, 4-piston fixed caliper, radially mounted
Brakes RearSingle disc, diameter 9.5″, single-piston floating caliper
Tires Front110/80 R19
Tires Rear150/70 R17
Fuel Tank Capacity3.0 gal.
ColorCosmic Black 3, Sport, Rally
AlternatorThree-phase alternator 308 W
Battery12 V / 8 Ah
Headlight
Tail LightLED Tail Light
Overall Length81.7”
Overall Width34.6”
Overall Height48.8”
Wheelbase55.9″
Castor3.9″
Seat Height32.8” (OE low seat: 32.3”, OE high seat: 33.4”
Unladen weight, road ready, fully fueled
386 lbs
Warranty
2022 BMW G310GS Adventure Features​
Effortless single-cylinder engine​
With Ride by Wire, the engine throttle response is effortless.
Adjustable clutch and brake levers​
With the multi-level adjustable clutch and brake levers, you can reduce the distance to your handlebars – for easy and comfortable control while riding.
Typical GS flyline​
Striking design elements emphasize the distinctive flyline, while the proven GS ergonomics make riding on a variety of surfaces exceedingly enjoyable.
Gold anodized inverted fork​
The stable inverted fork delivers precise steering and a comfortable ride.
License plate carrier with LED brake lights and flashing turn indicators​
With the new LED brake lights and flashing turn indicators, you are more visible when turning and can confidently get to your destination.
LED headlights are standard equipment​
With the new LED headlights for both low and high beams, night becomes day and the path before you is well illuminated.
Suspension element​
The successful coordination of spring and damper not only provides a high level of riding comfort, but also aid stability.
Convenient luggage carrier​
The sturdy luggage carrier serves as the base for your luggage, whether you have a topcase or roll bag.
2022 BMW G310GS Adventure Photos​
2022 BMW G310GS Adventure 2022 BMW G310GS Adventure 2022 BMW G310GS Adventure 2022 BMW G310GS Adventure
2022 BMW G310GS Adventure Videos​
2022 BMW G 310 GS Great Adventure For Newbies
2022 BMW G 310 GS
BMW Official Websites​
The post 2022 BMW G310GS Adventure [Specs, Features, Photos] appeared first on webBikeWorld.
