2022 Ducati Superleggera V4 [Specs, Features, Photos]
The 2022 Ducati Superleggera V4: Carbon Everywhere With More Tech Than Silicon Valley​
The epitome of engineering excellence, cutting-edge technology, and aerodynamic design. The 2022 Superleggera V4 represents the only motorcycle in the world approved for road use with a carbon fiber frame, swinging arm, and rims with an unbeatable power/weight ratio of 1.54 hp/kg.
The 2022 Ducati Superleggera V4 remains unchanged for the 2022 Ducati lineup, but what is there to change? For starters, this is the world’s only homologated bike with a carbon chassis. Those biplane wings create more downforce than Ducati’s MotoGP bike, while its quoted power with the Racing Kit installed is 234 hp. It’s one of the most advanced Ducati Motorcycles ever made, featuring cutting-edge technology, a sleek design aesthetic, and a fearsome power-to-weight ratio.
The Italian Manufacturer also gave the Ducati Superleggera V4 more tech than Silicon Valley. From advanced cornering ABS to multi-level traction control. Listed below for your pleasure:
  • ABS Cornering EVO
  • Ducati Traction Control (DTC) EVO 2
  • Ducati Slide Control (DSC)
  • Ducati Wheelie Control (DWC) EVO
  • Ducati Power Launch (DPL)
  • Ducati Quick Shift up/down (DQS) EVO 2
  • Engine Brake Control (EBC) EVO
The TFT dashboard on the Ducati Superleggera V4 has an exclusive“Race GP” interface developed with the guidance of Andrea Dovizioso from MotoGP because when you’re fully focused on the race, you only have a few fractions of a second to get key information.
Produced in a limited edition of only 500 numbered units and accompanied by a certificate of authenticity, the new Superleggera V4 is the most exclusive Ducati ever produced.
The 2022 Ducati Superleggera V4 starts at MSRP: $100,000 USD / $120,000 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Ducati Superleggera V4 in one place.
  • Price:
    • 2022 Ducati Superleggera V4 MSRP: $100,000 USD / $120,000 CAD
    • Immensely powerful 998 cc Desmosedici Stradale engine
    • Carbon fiber frame
    • Carbon fiber swingarm
    • Carbon fiber fairings
    • Carbon fiber wheels
    • Power output of 234 HP with Titanium Akrapovic exhaust installed
    • Suit of rider aid technology
Main Specs​
  • Engine: 998 Desmosedici Stradale 90-degree V4 engine
  • Power: 224 – 234 HP
  • Torque: 85.6 – 87.7 lb-ft
  • Dry Weight: 335 – 350 lbs (152.2 – 159 kg)
  • Seat Height: 32.9 in (835 mm)
Competitors​
  • BMW M1000RR
2022 Ducati Superleggera V4 Specifications​
Engine998cc, Desmosedici Stradale 90° V4, lightened, counter-rotating crankshaft, 4 Desmodromic timing, 4 valves per cylinder, liquid-cooled
Power224 hp
Bore x Stroke81 x 48.4 mm
Compression Ratio14.0:1
Fuel InjectionElectronic fuel injection system. Twin injectors per cylinder. Full ride-by-wire elliptical throttle bodies with aerodynamic valves. Variable length intake system
Exhaust4-2-1-2 system, with 2 catalytic converters and 2 lambda probes
Torque116 Nm (85.6 lb-ft) @ 11,750 rpm – 119 Nm (87.7 lb-ft) @ 11.750 rpm with full racing exhaust
ClutchHydraulically controlled slipper dry clutch
Transmission6 speed with Ducati Quick Shift (DQS) up/down EVO 2
Final DriveRegina ORAW2 chain ; Front sprocket 15; Rear sprocket in Ergal 42
Suspension FrontFully adjustable 43 mm Öhlins NPX25/30 pressurized fork with TiN treatment, billet fork bottoms, lightweight springs, fully adjustable.
Suspension RearFully adjustable Ohlins TTX36 unit with GP valve and titanium spring. Carbon fiber single-sided swingarm.
Brakes Front2 x 330 mm semi-floating discs, radially mounted Brembo Monobloc Stylema® R 4-piston callipers with Cornering ABS EVO
Brakes Rear245 mm disc, 2-piston calliper with Cornering ABS EVO
Tires FrontPirelli Diablo Supercorsa SP 120/70 ZR17
Tires RearPirelli Diablo Supercorsa SP 200/60 ZR17
Fuel Tank Capacity16 l – 4.23 gallon (US)
ColorRed SLV4
Ignition
HeadlightLED
Max Length
Max Width
Max height
Wheelbase1.480 mm (58,3 in)
Rake24,5°
Trail
Seat Height835 mm (32.9 in)
Dry Weight159 kg (350 lb) – 152.2 kg (335.5 lb) with racing kit
Warranty24 months, Unlimited mileage
2022 Ducati Panigale V4 R Features​
CONCEPT​
Superleggera V4 is a project where excellence, engineering and dreams converge in a direction that is as ambitious as it is performative.
New Superleggera V4​
335.5 lb dry weight for 234 HP (in race configuration) for this incredible product. These numbers are achieved thanks to the full carbon fiber frame and a vast use of titanium and magnesium components.
Crafting the Dream​
Superleggera V4 is crafted with all the passion, precision, and dedication to perfection Ducati has to offer. Shaping lightness into speed emotions with our most sophisticated engine ever, top of the line components and our most technologically advanced electronics.
2022 Ducati Panigale V4 R Photos​
2022 Ducati Superleggera V4 2022 Ducati Superleggera V4 2022 Ducati Superleggera V4 2022 Ducati Superleggera V4
2022 Ducati Panigale V4 R Videos​
Superleggera V4: Performance
The post 2022 Ducati Superleggera V4 [Specs, Features, Photos] appeared first on webBikeWorld.
