2022 Harley Davidson Electra Glide Standard [Specs, Features, Photos]
The 2022 Harley Davidson Electra Glide Standard: Batwing Brilliance
Baggers are among the most popular choice in the 2022 Harley Davidson lineup. The Electra Glide Standard is aimed at the purist wanting the bones to build their own bagger exactly like they have always dreamed.
Harley Davidson equips the Electra Glide Standard with the Milwaukee-Eight® 107 V-Twin engine packs 92.5 HP and 110 ft-lb of American-made torque. Cruise control, floorboards, Reflex
Linked Brembo® brakes with standard ABS, and 2.3 cu ft hard bags set this Standard up for miles of comfortable touring.
Strangely this model does not appear in the 2022 Canadian lineup.
1 color for the 2022 Harley Davidson Electra Glide Standard: Vivid Black.
The 2022 Harley Davidson Electra Glide Standard starts at $19,429 USD / N/A CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Electra Glide Standard in one place.
  • Price: $19,429 USD / N/A CAD
    • Reflex
      Linked Brembo® Brakes With Standard Abs
    • Cruise Control
    • Floorboards
    • Batwing Fairing and Hard Bags
Main Specs​
  • Engine: 107 ci V-twin
  • Power: 92.5 HP (estimated)
  • Torque: 110 lbs-ft @ 3000 RPM
  • Wet Weight: 820 lbs (372 kg)
  • Seat Height: 26.1 inches (680 mm)
Competitors​
2022 Harley Davidson Electra Glide Standard Specifications​
Engine107 cu in, Milwaukee-Eight® 107
Engine Torque111 ft-lb
Bore x Stroke3.937 in. X 4.375 in.
Compression Ratio
10.0:1
Starter
ExhaustChrome, 2-1-2 dual exhaust with tapered mufflers
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
49 mm Dual Bending Valve
Rear Shocks
Premium Low Hand-Adjustable Rear Suspension
Wheels, Front Type
Impeller Cast Aluminum
Wheels, Rear Type
Brakes Front
32 mm
Brakes Rear4-piston fixed
Tires Front
BW 130/80B17 65H
Tires Rear
BW 180/65B16 81H
Fuel Tank Capacity6 gal.
ColorVivid black
Ignition
HeadlightAll LED headlamp
Length
94.5 in.
Trail
6.7 in.
Rake26
Wheelbase
64 in.
Ground Clearance
4.7 in.
Seat Height
26.1 in.
Weight, As Shipped
781 lb.
Warranty
2022 Harley Davidson Electra Glide Standard Features​
Milwaukee-Eight Big Twin Engine​
A powerful, smooth-running engine with crisp throttle response and a pure, soul-satisfying rumble.
2022 Harley Davidson Electra Glide Standard Photos​
2022 Harley Davidson Electra Glide Standard Videos​
Before You Buy a Street Glide, Watch This | 2022 Electra Glide Test Ride:
2022 Harley-Davidson Electra Glide Standard in Vivid Black:
The post 2022 Harley Davidson Electra Glide Standard [Specs, Features, Photos] appeared first on webBikeWorld.
