2022 Harley Davidson Street Glide ST [Specs, Features, Photos]
The 2022 Harley Davidson Street Glide ST: The Batwing Beauty!
The Street Glide ST what batwing fans have been wanting Harley Davidson to build. Tucking up the key hard bits like the exhaust and bags allows for improved cornering clearance. Then fitting the front end with a 19-inch tire versus a CVO like 21-inch, keeps this American bike feeling light and nimble. This is for sure the performance-minded Street Glide in the 2022 Harley Davidson lineup, for more reasons than just the bigger engine.
Taking advantage of the Milwaukee-Eight® 117 V-Twin engine and all 126 lbs-ft of torque, really gets the Street Glide ST moving with attitude. As outfitted with goodies like the Boom! Box GTS infotainment system, the only available option is the RDRS Electronics Package, which in my opinion is well worth it.
2 Color choices for the 2022 Harley Davidson Street Glide ST: Vivid Black, or Gunship Gray
The 2022 Harley Davidson Street Glide ST starts at $29,999 USD / $36,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Street Glide ST in one place.
  • Price: $29,999 USD / $36,999 CAD
    • Milwaukee-Eight® 117 V-Twin engine
    • Bronze Prodigy Wheels
    • Boom! Box GTS infotainment system
    • Optional RDRS Electronics Package
Main Specs​
  • Engine: 117 ci V-twin
  • Power: 103 HP (estimated)
  • Torque: 126 lbs-ft @ 3750 RPM
  • Wet Weight: 814 lb. (369 kg)
  • Seat Height: 26.7 in. (710 mm)
Competitors​
2022 Harley Davidson Street Glide ST Specifications​
EngineMilwaukee-Eight® 117
Engine Torque127 ft-lb
Bore x Stroke4.075 in. x 4.5 in.
Compression Ratio
10.2:1
Starter
ExhaustDual, with crossover
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
49mm Dual Bending Valve
Rear Shocks
Premium standard height hand-adjustable rear suspension
Wheels, Front Type
Bronze Prodigy
Wheels, Rear Type
Bronze Prodigy
Brakes Front
32mm Dual floating rotors
Brakes Rear4-piston fixed
Tires Front
130/60B19 61H
Tires Rear
BW 180/55B18 80H
Fuel Tank Capacity6 gal.
Color
Ignition
HeadlightAll LED headlamp
Length
94.7 in.
Trail
6.7 in.
Rake26
Wheelbase
64 in.
Ground Clearance
5.5 in.
Seat Height
26.7 in.
Weight, As Shipped
Vivid Black, Gunship Gray
Warranty
2022 Harley Davidson Street Glide ST Features​
MILWAUKEE-EIGHT® 117 V-TWIN​
The new pinnacle of torque and displacement with a factory-installed powertrain. Precision oil/air cooling. 126 ft. lbs. of torque at 3750 RPM. Tuned heavy breather intake and high flow exhaust maximize engine performance, a boost you can feel with every twist of the throttle.
West Coast Styling​
BLACKED OUT EVERYTHING
Front end, controls, powertrain and exhaust. The only bright bits are pushrod tubes and tappet covers, and machined cylinder fins.
SPORT TOURING PROFILE
Standard bag height for a trimmed look and more room to lean.
FIXED SHARKNOSE FAIRING
This frame-mounted fairing keeps the cross-winds and traffic buffeting at bay, with a design that is unmistakably Harley-Davidson.
STANDARD FEATURES​
Standard Anti-Lock Braking System (ABS)
Boom! Box GTS infotainment system with color touch screen, two fairing-mount speakers and hidden radio antenna
Emulsion-technology rear shocks, with a single knob to hydraulically adjust pre-load for optimal ride and control
49mm forks with dual bending valve suspension technology
Daymaker LED headlamps
Smart Security System with proximity-based, hands-free security fob
OPTIONAL CORNERING RIDER SAFETY ENHANCEMENTS​
Cornering Electronically Linked Brakes
Cornering-ABS
Cornering-Traction Control with modes
Drag Torque Slip Control
Vehicle Hold Control
Tire Pressure Monitoring (TPMS)
2022 Harley Davidson Street Glide ST Photos​
2022 Harley Davidson Street Glide ST 2022 Harley Davidson Street Glide ST 2022 Harley Davidson Street Glide ST 2022 Harley Davidson Street Glide ST
2022 Harley Davidson Street Glide ST Videos​
A REAL 2022 Harley Street Glide ST Test Ride & Review
2022 Harley-Davidson Road & Street Glide ST Review (Can a “PERFORMANCE BAGGER” Keep Up?)
The post 2022 Harley Davidson Street Glide ST [Specs, Features, Photos] appeared first on webBikeWorld.
