2022 Indian Scout Rogue Sixty [Specs, Features, Photos]
The 2022 Indian Scout Rogue Sixty Is a New Addition to the Scout Lineup​
The Indian Scout Rogue Sixty debuted alongside its older sibling, the Scout Rogue, earlier this year. The two models are the latest additions to the Scout range and the 2022 Indian Motorcycle portfolio. While they’re almost identical visually, the Scout Rogue Sixty, as its name suggests, features a smaller 983cc (60 cubic inch) engine.
Some interesting styling elements define the new Scout Rogue Sixty. The American manufacturer states that the new models combine “iconic design with contemporary style,” which appears to be the case. The Scout Rogue Sixty features the same quarter fairing, mini ape-hanger handlebars, solo seat, blacked-out fenders and valve covers, and 19-inch front wheel as its bigger brother. The only visual differences include the tank badging and the color options.
As mentioned above, the Scout Rogue Sixty features a slightly smaller engine. The V-twin that powers this motorcycle displaces 983cc, producing 78 hp and 65 lb-ft of torque. Unlike the Scout Rogue, which features a 6-speed gearbox, the Rogue Sixty gets a 5-speed unit.
The 2022 Indian Scout Rogue Sixty is available in three color schemes — Black Metallic, Bronze Smoke, and Titanium Smoke — with the Black Metallic also available without the option of ABS.
The 2022 Indian Scout Rogue Sixty starts at $11,249 USD / $13,699 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Indian Scout Rogue Sixty in one place.
Motorcycle Overview​
  • Price: $11,249 USD / $13,699 CAD
    • Iconic design with contemporary styling elements
    • Low seat height for easy accessibility and control
    • 19-inch front/16-inch rear wheel setup with Metzeler Cruisetec tires
Main Specs​
  • Engine: 983cc V-twin
  • Power: 78 hp
  • Torque: 65 lb-ft
  • Wet Weight: 540 lbs (245 kg)
  • Seat Height: 25.6 in (649 mm)
Competitors​
2022 Indian Scout Rogue Sixty Specifications​
Engine983cc, Liquid Cooled V-Twin (60 degrees)
Engine Power78 HP
Bore x Stroke3.661 in x 2.898 in (93 mm x 73.6 mm)
Compression Ratio11.0:1
Fuel SystemClosed loop fuel injection / 54 mm bore
ExhaustSplit Dual Exhaust w/ Cross-over
ClutchWet, Multi-Plate
Transmission6 Speed
Final Drive2.357 : 1
Suspension Front41mm Telescopic Fork
Suspension RearDual Shocks
Brakes FrontSingle / 298 mm Rotor / 2 Piston Caliper
Brakes RearSingle / 298 mm Rotor / 1 Piston Caliper
Tires FrontMetzeler Cruisetec 130/60B19 61H
Tires Rear
Metzeler Cruisetec 150/80B16 77H
Fuel Tank Capacity3.3 gal (12.5 L)
Color / GraphicsBlack Metallic, Black Metallic ABS, Bronze Smoke ABS, Titanium Smoke ABS
Ignition
HeadlightLED Headlamp
Tail LightLED Taillight
Overall Length87.5 in (2223 mm)
Overall Width39.2 in (995 mm)
Overall Height46.5 in (1,181 mm)
Wheelbase62 in (1,576 mm)
Ground Clearance5.1 in (129 mm)
Seat Height25.6 in (649 mm)
Weight (Empty Tank / Full of Fuel)
520 lbs (236 kg) / 540 lbs (245 kg)
Warranty2 Years, Unlimited Miles
2022 Indian Scout Rogue Sixty Features​
Be part of something bigger​
With modern inspired style and amenities, the Scout Rogue Sixty brings a new spirit to the Scout lineup.
DESIGNED TO MAKE A STATEMENT​
The quarter fairing gives the Scout Rogue a distinct look. Add accessories like LED lighting or a color-matched quarter fairing to make it tailored to you.
Sport Style Seat​
The sport style seat provides a sleek look while keeping riders confidently in command of their motorcycle.
Aggressive Ergos​
Mini-ape handlebars complement the bold stance, begging riders to ride as aggressively as it looks.
19" front wheel​
The 19-inch front wheel adds to the aggressive nature of the Scout Rogue Sixty – both in style and agile handling.
Liquid-Cooled V-twin Engine​
A blacked-out, liquid-cooled, 60-cubic-inch, 78 hp V-twin engine guarantees a thrilling ride. Electronic fuel injection and liquid cooling are just some of the advanced engineering features giving the Scout Rogue Sixty unmistakable power every time you fire up the engine.
ENGINEERED FOR EASE​
The lightweight, cast aluminum frame and low seat make for an expertly balanced bike that’s easy to handle at all speeds.
Full Stop​
Eventually, you’ll have to stop. ABS available on all colors for superior stopping power.
2022 Indian Scout Rogue Sixty Photos​
2022 Indian Scout Rogue Sixty 2022 Indian Scout Rogue Sixty 2022 Indian Scout Rogue Sixty 2022 Indian Scout Rogue Sixty
2022 Indian Scout Rogue Sixty Videos​
2022 Indian Scout Rogue Review by Bike World:
2022 Harley-Davidson Nightster vs Indian Scout Rogue by Motorcycle.com:
Indian Motorcycle Official Websites​
The post 2022 Indian Scout Rogue Sixty [Specs, Features, Photos] appeared first on webBikeWorld.
