2022 Yamaha YZF-R7 [Specs, Features, Photos]
2022 Yamaha YZF-R7: A Brand New Super Twin​
Brand new for Yamaha’s 2022 lineup is the 2022 YZF-R7. After failing to catch up with Euro-5 regulations, Yamaha decided to completely scrap one of their best-selling motorcycles of all time: the Yamaha YZF R6 (an inline-four beast that was the perfect stepping stone for intermediate and advanced riders before graduating to maximum R1 performance). After a brief period of silence, Yamaha finally announced that they would be taking their CP2 mill borrowed from the highly successful MT-07 and would be translating it into a new supersport model dubbed “the YZF-R7”.
Although it takes a slightly different approach to the supersport formula by offering a two-cylinder engine instead of the typical four that are usually found in bikes of this nature, Yamaha still checks all the boxes when it comes to power output and performance. The 689cc CP2 engine with A&S clutch provides a torque-heavy output perfect for powering you out of corners on both the track and street. 74 horsepower and 50 lb-ft of torque ensure that this new Japanese model can compete with the likes of its rivals in this newly burgeoning super-twin market.
Including fully-adjustable inverted 41 mm front forks, ABS, radial-mount front brake calipers, lightweight 10-spoke wheels, and even an optional quick shift system – this new model is sure to leave a good impression on the middleweight motorcycle community.
As with all models in Yamaha’s R-Series, the R7 also comes in a limited edition colorway for 2022 in the form of the “World GP 60th Anniversary Edition”.
The 2022 Yamaha YZF-R7 starts at $8,999 USD / $10,799 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Yamaha YZF-R7 in one place.
2022 Yamaha YZF-R7
  • Price: $8,999 USD / $10,799 CAD
    • Rider-Assist Modes
    • A&S clutch
    • Brand new model, meaning brand new design
    • Yamaha’s tried-and-true CP2 engine
Key Specs​
  • Engine: 689cc 2-cylinder CP2 motor
  • Power: 74 HP
  • Torque: 50 lb-ft
  • Wet Weight: 414 lbs (188 kg)
  • Seat Height: 835 mm (32.8 in.) at lowest point
Key Competitors​
2022 Yamaha YZF-R7
2022 Yamaha YZF-R7 Specifications​
Engine689cc liquid-cooled, 4-stroke, DOHC inline twin-cylinder; 4-valves per cylinder
Power74 Hp
Bore x Stroke80.0mm x 68.6mm
Compression Ratio11.5:1
Fuel SystemFuel injection
Lubrication
Clutch
Transmission6-speed; multiplate wet clutch; with Assist & Slipper clutch
Final DriveChain
Suspension FrontTelescopic fork; 5.1-in travel, adjustable for preload, rebound and compression
Suspension RearLinked-type Monocross shock, adjustable preload and rebound; 5.1-in travel
Brakes Front298mm hydraulic disc
Brakes Rear245mm hydraulic disc
Tires Front120/70ZR17 Bridgestone BATTLAX HYPERSPORT S22F E
Tires Rear180/55ZR17 Bridgestone BATTLAX HYPERSPORT S22R E
Fuel Tank Capacity3.4 gal
Color
Ignition
Headlight
Overall Length81.5 in
Overall Width27.8 in
Overall Height45.7 in
Wheelbase54.9 in
Ground Clearance5.3 in
Seat Height32.9 in
Wet Weight414 lb
Warranty1 Year (Limited Factory Warranty)
2022 Yamaha YZF-R7
2022 Yamaha YZF-R7 Features​
TOP FEATURES​
  • Torquey CP2 Powerplant
    Yamaha’s proven 689cc liquid-cooled, inline 2-cylinder DOHC fuel-injected CP2 engine delivers excellent power and performance throughout the rpm range for an exhilarating ride and a true supersport experience. Its 270-degree crankshaft delivers linear torque for exciting acceleration and limited vibration.
  • All-New A&S Clutch
    A first for Yamaha’s CP2 platform, the all-new Assist and Slipper clutch reduces clutch lever force while providing seamless downshifts and a controlled feeling over the bike’s engine braking. This helps make the supersport riding experience more accessible to more riders. For fast and smooth upshifts, an optional Quick Shift System (QSS) is also available on the YZF-R7.
  • Thin Proportions for Perfect Control
    All-new dimensions give the YZF-R7 the slimmest proportions of the entire R-Series family, aiding in confident cornering performance on the track and quick, agile direction changes on twisty roads. The slim design also reduces wind resistance for optimal aerodynamics, while new bodywork incorporates the rider’s body to improve the flow of air around the bike.
  • Sporty New Suspension
    The YZF-R7 features an inverted 41mm front fork with optimized spring rate and damping settings for an excellent front-end feel during cornering and braking. An all-new linked-type Monocross single-shock with adjustable spring preload and rebound damping strikes an ideal balance between ride comfort and supersport performance, for capability across a wide range of uses from urban commuting to track days.
  • Adaptive Bi-Functional LED Headlight
    The iconic R-Series M-shaped intake duct and twin-eye look compliments the all-new YZF-R7 along with an adaptive bi-functional LED headlight.
  • Linear Torque with Smooth Acceleration
    The all-new YZF-R7 boasts a 270-degree crankshaft that delivers a tactile experience of pulse and acceleration with limited vibration. The CP2 engine provides the rider a linear-feeling direction connection from the throttle to the rear wheel.
    A first for Yamaha’s CP2 platform, the all-new Assist and Slipper clutch reduces clutch lever force providing seamless downshifts and a controlled feeling over the bike’s engine braking that helps make the supersport experience more accessible to more riders. For fast and smooth upshifts, an optional Quick Shift System (QSS) is also available on the YZF-R7.
  • Quick Shift System for Smooth Upshifts
    An optional Quick Shift System (QSS) can be paired with the YZF-R7 to help provide speedy, smooth upshifts. When the sensor on the shift rod detects movement in the gearshift lever, adjustments are made in the engine output according to ECU calculations to instantly cancel out the drive torque of the engaged gear to promote swifter shifting of gears.
  • Strong and Lightweight Pistons
    Forged aluminum pistons with direct-plated cylinders integrated with the crank case makes for lighter weight and excellent strength at higher temperatures, ensuring reliability at higher rpm.
CHASSIS/SUSPENSION​
  • Supersport Riding Position
    The carefully developed rider’s triangle puts you in a clear supersport riding position. The YZF-R7’s racing-inspired cockpit puts you in a comfortable confidence-inspiring position. A new seat, combined with new tank covers featuring deep knee pockets, provides optimal hip and knee positioning. Riders get the freedom to adjust positions while also maintaining a firmly planted feeling in corners plus sturdy body hold under braking. Separate clip-on handlebars are set in relation to the riders hips and footpeg positions for an aggressive rider position.
  • Inverted Front Fork
    The YZF-R7 features a preload, rebound and compression adjustable inverted KYB 41mm front fork featuring optimized spring rates and damping settings for an excellent front-end feel during cornering and braking.
  • Lightweight Frame Tuned for Rigidity Balance
    A high-strength steel frame with a rigid-mount aluminum center brace provides an optimized balance of rigidity for linear and nimble responsiveness to rider input.
  • Monocross Rear Shock
    The all-new linked-type Monocross single-shock design reduces weight and further centralizes mass. Its adjustable spring preload and rebound damping are tuned to strike a balance between ride comfort and sporty performance, for capability across a wide range of uses, from urban commuting to track days.
  • Potent Braking
    A newly-designed radial brake master cylinder from Brembo combined with radial-mounted front brake calipers on dual 298mm front brake rotors optimize braking pressure for linear delivery with excellent performance and controllability. ABS is standard.
    All-new dimensions give the YZF-R7 the slimmest proportions of the entire R-Series family, aiding in sporty riding with optimal handling for cornering on the track and agility for changing lean directions on twisty roads. The slim design reduces wind resistance for optimal aerodynamics with new bodywork that incorporates the rider’s body to influence the flow of air around the bike.
    The YZF-R7 features an inverted 41mm front fork with optimized spring rate and damping settings for an excellent front-end feel during cornering and braking. An all-new linked-type Monocross single-shock with adjustable spring preload and rebound damping strikes a balance between ride comfort and supersport performance, for capability across a wide range of uses, from urban commuting to track days.
ADDITIONAL FEATURES​
  • LED Lighting
    Light Emitted Diode (LED) elements are used for the front and rear turn signals, the tail light unit and the headlights. Not only do LEDs offer long life with minimal power draw, they provide brilliant illumination for confidence and visibility day or night.
  • Refined Sportbike Ergonomics
    Thanks to the low-profile fuel tank design and compact clip-on handlebar position, the rider is able to naturally grip the machine for confidence, especially when tucking aggressively behind the windscreen on the racetrack.
  • Sleek R-Series Styling
    The YZF-R7’s aggressive new design is next generation R-Series styling, with the slimmest bodywork in the supersport lineup for optimal aerodynamics, handling and agility. The glaring face of the YZF-R7 features a compact LED headlight housed in the iconic M-shaped intake duct, while its sharp tail is reminiscent of the YZF-R1.
ELECTRONICS​
  • Digital LCD Instrumentation
    A new full-LCD instrument panel informs the rider of gear position, fuel capacity, real time and average fuel economy, water temp, clock and more—all presented in a high-contrast display.
2022 Yamaha YZF-R7 Photos​
2022 Yamaha YZF-R7 2022 Yamaha YZF-R7 2022 Yamaha YZF-R7 2022 Yamaha YZF-R7
2022 Yamaha YZF-R7 Videos​
Yamaha R7 vs Competition [DETAILED COMPARISON]
2022 Yamaha R7 | 1 Month Review
Yamaha Motorcycles Official Websites​
The post 2022 Yamaha YZF-R7 [Specs, Features, Photos] appeared first on webBikeWorld.
