2023 Aprilia RSV4 / RSV4 Factory [Specs, Features, Photos]
The 2023 Aprilia RSV4 May Very Well Be The Definitive Superbike
2023 brings another rendition of Aprilia’s legendary RSV4 superbike, and while there doesn’t appear to be much new with the bike this year, we’re still gobsmacked at how well this Italian sport bike holds up.
Aprilia has been using the V4 engine platform for a while now, and we really aren’t complaining that the 1100cc powerhouse hasn’t received an overhaul just yet. Producing a marketed 217 hp and 92.2 lb-ft of torque, we can imagine that this thing lives up to Aprilia’s slogan – “Be A Racer”.
As is standard with Aprilia, the V4 can be optioned in either the standard model or the Factory model, which outfits the already impressive bike with a handful of race-ready goodies, such as forged wheels, semi-adaptive suspension, and uprated Brembos.
Aprilia’s entire lineup receives some racing tech from the brand’s MotoGP racing efforts, but this is especially apparent with the RSV4 – Aprilia’s top model, thanks to the bike’s aggressive, checkered flag-ready styling, which matches its performance. The bike is unmistakably an Aprilia, thanks to that legendary headlight design, but some key tweaks, like front-mounted winglets and a series of optional liveries, truly set it off.
Aprilia hasn’t spared many expenses when it comes to features on the RSV4, the bike comes equipped with the APRC (Aprilia Performance Ride Control) system, which includes a half dozen riding modes, various engine maps, and a plethora of riding controls, like wheelie control and traction control.
The 2023 Aprilia RSV4 starts at $18,999 USD/ $21,095 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc., so you can read up on the new 2023 Aprilia RSV4/Factory in one place.
 2023 Aprilia RSV4 / RSV4 Factory 2023 Aprilia RSV4 / RSV4 Factory
  • Price: $18,999 USD/ $21,095 CAD
    • Full LED lighting
    • APRC System
    • Optional Factory Model
    • Refined V4 Engine
  • Engine: 1,099cc V4
  • Power: 217 HP
  • Torque: 92.19 lb-ft
  • Weight (Wet): 445 lbs (201.9 kg)
  • Seat Height: 33.5 in (85.09 cm)
  • Ducati Panigale V2
  • Yamaha YZF-R1
  • Kawasaki ZX-10R
  • Suzuki GSX-R1000
  • Honda CBR-1000RR-R
2023 Aprilia RSV4 / RSV4 Factory Specifications​
Engine1.099cc, Aprilia longitudinal 65° V-4 cylinder, 4-stroke, liquid cooled, double overhead camshafts (DOHC), four valves per cylinder
Engine Power217 HP (159.5 kW) at 13,000 rpm
Bore x Stroke
Compression Ratio
Fuel System
Starter
Torque92.19 ft-lbs (125 Nm) at 10,500 rpm
Clutch
TransmissionExtractable 6-speed – Gear lever with Aprilia Quick Shift electronic system (AQS)
Final Drive
Suspension FrontSachs fork, Ø 43 mm stanchions, adjustable spring preload, compression and rebound, 127 mm travel
Suspension RearSachs monoshock adjustable: hydraulic compression and rebound damping and spring pre-load, 130 mm travel
Brakes FrontDual 330-mm diameter floating stainless steel disc with lightweight stainless steel rotor and aluminum flange with 6 pins.
Brembo Stylema® monobloc radial calipers with 4 Ø30mm opposing pistons. Sintered pads. Radial pump and metal braided
brake hose
Brakes RearØ 220 mm disc. Brembo caliper with two 32 mm separate pistons. Master cylinder with built in reservoir and metal braided
hose
Front Wheel3.5”x17” aluminum alloy wheel rim, 3 split spoke design. Tire: 120/70 ZR 17”
Rear Wheel6”x17” aluminum alloy wheel rim, 3 split spoke design. Tire 200/55 ZR 17”; alternative: 190/50 ZR 17, 190/55 ZR 17
Fuel Tank Capacity4.75-gal (including 1.05-gal reserve
Color
Ignition
HeadlightLED
Tail Light
Overall Length
Overall Width
Saddle Height
Wheelbase
Ground Clearance
Seat Height33.5 inches
Wet Weight445-lbs
Warranty
2023 Aprilia RSV4 / RSV4 Factory Features​
MotoGP aerodynamics​
Instead of being exposed appendages on the sides of the bike, the winglets are now integrated into the double fairing. Analysed using software and in the wind tunnel, their efficiency has been rigorously tested on the road and track by Aprilia Racing’s aerodynamic engineers. The result is a bike that delivers even greater stability, aerodynamics and performance than ever before.
An engine to set your heart racing​
The latest RSV4 and RSV4 Factory models are all powered by the same 1100 cc, the first mass-produced high-performance narrow V 4-cylinder in the world. Lightweight and compact like no other, it delivers torque of up to 125Nm at 10500 rpm. Horsepower remains at an impressive 217, already hard to beat, but it now meets Euro 5 criteria and breaks the 305 km/h barrier at top speed.
Designed for comfort​
Improved ergonomics come in the form of a new fuel tank, and through lowering both the seat and foot pedal-footrest by 9 mm, creating a more natural, relaxed riding position, even for taller riders.
Also new is the Magneti Marelli ECU 11MP control system for improved management of the Öhlins Smart EC 2.0 suspension and a riding experience like never before.
Aprilia RSV4 and RSV4 Factory​
The RSV4 is also available in a Factory option. Common to both is the revamped V4 1099cc engine, but the Factory version sports standard elements such as forged aluminium wheel rims, an Öhlins Smart EC 2.0 semi-active suspension system and Brembo Stylema brake callipers.
RSV4 FACTORY​
Speed White Limited Edition
Dominated by a white that enhances the aerodynamic lines and its design with built-in winglets, the Speed White livery is combined with red wheel rims and adorned with the Aprilia inscription on the side and sport graphics inspired by the Aprilia RS-GP prototype playing a leading role in the 2023 MotoGP World Championship
2023 Aprilia RSV4 / RSV4 Factory Photos​
 2023 Aprilia RSV4 / RSV4 Factory  2023 Aprilia RSV4 / RSV4 Factory  2023 Aprilia RSV4 / RSV4 Factory  2023 Aprilia RSV4 / RSV4 Factory
2023 Aprilia RSV4 / RSV4 Factory Videos​
The 2021 Aprilia RSV4 Factory Is Now My Favorite Sport Bike by MotoJitsu:
Aprilia RSV4 1100 Factory Full Power by ImKay
Aprilia Official Websites​
The post 2023 Aprilia RSV4 / RSV4 Factory [Specs, Features, Photos] appeared first on webBikeWorld.
