2023 BMW S 1000 RR [Specs, Features, Photos]
The 2023 BMW S 1000 RR Is A Race Bike Suitable for Every Day Riding
The 2023 BMW S 1000 RR is BMW’s high-performance sportbike designed for both track and street use. It features a 999cc engine that produces 205 horsepower and can reach a top speed of 186 miles per hour. The bike has a lightweight aluminum frame and a sleek, aerodynamic body that contributes to its nimble handling and stability at high speeds. The S 1000 RR has numerous features to ensure control of all that power with its fantastic adjustable suspension and a comprehensive electronics package that includes traction control and ABS. In addition, it has a quick shifter for smooth gear changes and an up/down feature for convenience.
Other “street type” conveniences that are standard in other bikes in this year’s BMW lineup like cruise control, heated grips and a passenger package are added options on this model. Overall, the BMW S1000RR is a top-tier sportbike that offers an impressive combination of power, agility, and technology for riders who demand the best and compares well with other European bikes in this class.
The 2023 BMW S 1000 RR starts at $17,895 USD / $20,395 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 BMW S 1000 RR in one place.
2023 BMW S 1000 RR 2023 BMW S 1000 RR
  • Price: $17,895 USD / $20,395 CAD
    • ABS/Pro riding modes/Wheelie Control/Traction Control
    • 6.5” TFT display
    • M Chassis kit
    • Shift assistant
  • Engine: 999cc Water/oil-cooled in-line four cylinder four stroke
  • Power: 205 horsepower
  • Torque: 83 lb-ft
  • Weight: 385.8 lbs (175 kgs)
  • Seat Height: 32.4 inches (823 mm)
2023 BMW S 1000 RR Specifications​
Engine999cc, 4-cylinder, 4-stroke in-line engine (BMW ShiftCam)
Engine Power205 hp at 13,750 rpm
Bore x Stroke3.15” x 1.96”
Compression Ratio13.3 : 1
Fuel deliveryElectronic injection, variable intake pibe
Max Torque83 lb-ft at 11,000 rpm
ClutchMultiplate clutch in oil bath, anti-hopping clutch, with self-reinforcement
TransmissionClaw-shifted 6-speed gearbox with straight cut gears
DriveChain 525 17/46
Suspension FrontUpside-down telescopic fork, diameter 45 mm, spring preload, rebound and compression stages adjustable
Suspension RearAluminium swing arm, full-floater pro, central spring strut, adjustable rebound and compression-stage damping, adjustable preload
Brakes FrontTwin disc brake, Ø 320 mm 4.5 mm, radial 4-piston fixed caliper (5 mm M wheels)
Brakes RearSingle disc brake, diameter 220 mm, 1-piston floating caliper
Tires Front120/70 ZR17
Tires Rear190/55 ZR17 (with M wheels: 200/55 ZR17)
Fuel Tank Capacity4.4 gal.
ColorLight White/M Motorsport, Passion, Black Storm Metallic
ABSBMW Motorrad Race ABS (partial integral), Brake-Slide-Assist
Alternator450 W
Battery12 V / 5 Ah, lithium-ion
HeadlightLED headlight
Tail LightLED tail light
Overall Length81.6″
Overall Width33.4”
Overall Height47.4”
Wheelbase57.4”
Castor3.93”
Seat Height32.4”
Unladen weight, road ready, fully fueled
434.3 lbs (M Package 426.6 lbs)
Warranty
2023 BMW S 1000 RR Features​
Outstanding braking​
Pushing towards the head of the class: the brake originates from the M RR. For deceleration with maximum braking stability and feedback – paired with precise adaptation to Race ABS.
M Carbon tail-hump cover with camera adapter​
Attach an action cam to the carbon seat pad; featuring a recess with an adapter and install the GPS mouse of the M data logger including lap trigger.
New rear end with short license plate carrier​
More than just appearance: The new rear makes the RR seem even lighter, sportier and more dynamic. The optionally available M Cover kit for track days is easy to attach, just like in professional racing.
Optimized engine concept​
Details and transfers from motorsport: The cylinder head geometry is identical to that in the M RR. In addition, the power output is 205 hp.
Dynamic front view and tall windscreen​
Reduce helmet vibration: newly designed front with tall windscreen provides improved aerodynamics around the head. The isolation of the fork bridge brings about further aerodynamic advantages.
Performance-oriented M Data Logger with GPS-Laptrigger​
Work like the professionals: the optionally available M Data Logger with GPS-Laptrigger makes it possible to automatically record lap times and evaluate relevant riding data on more than 300 racetracks worldwide. European model shown.
Powerful M Lightweight battery​
Every ounce counts: the high-quality and durable M Lightweight battery with state-of-the-art lithium-ion technology saves a full 4.4 lbs of weight.
Efficient front and side trim panel with winglet​
Up to 37.7 lbs: front and side trim panels have been reworked for optimal downforce and improved aerodynamics. The winglets, familiar from the M RR, have been specially modified.
2023 BMW S 1000 RR Photos​
2023 BMW S 1000 RR 2023 BMW S 1000 RR 2023 BMW S 1000 RR 2023 BMW S 1000 RR
2023 BMW S 1000 RR Videos​
2023 BMW S 1000 RR review by MOTOBOB:
2023 BMW S 1000 RR Review by Bennetts Bike Social:
BMW Official Websites​
The post 2023 BMW S 1000 RR [Specs, Features, Photos] appeared first on webBikeWorld.
