2023 Harley Davidson Freewheeler [Specs, Features, Photos]
The 2023 Harley Davidson Freewheeler: Just Cruise
For 2023, the Freewheeler model, an American-made trike with attitude-soaked cruiser styling, receives a blacked-out makeover. Instead of the former bright finishes, the front end, headlight nacelle, tank console, hand and foot controls, powerplant, and exhaust all have black finishes. The end effect is a striking transformation in appearance that highlights this model’s unrefined, hot-rod attitude.
A prime engine choice in the 2023 Harley Davidson lineup, the Milwaukee-Eight® 114 has plenty of power to stretch your arms at the controls of the Freewheeler. Electric reverse, a massive weatherproof rear trunk, and bob-tailed fenders set this trike apart. As do the new cast aluminum wheels that I cannot stop staring at.
3 Color choices for the 2023 Harley Davidson Freewheeler: Vivid Black, White Sand Pearl, Bright Billiard Blue / Billiard Gray.
The 2023 Harley Davidson Freewheeler starts at $29,999 USD / $36,599 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Freewheeler in one place.
2023 Harley Davidson Freewheeler2023 Harley Davidson Freewheeler
  • Price: $29,999 USD / $36,599 CAD
    • Milwaukee-Eight® 114 V-Twin engine
    • Brembo ABS Brakes
    • 12” Mini Apes
    • Optional RDRS
  • Engine: 114 ci V-twin
  • Power: 100.5 HP (estimated)
  • Torque: 118 lbs-ft @ 3000 RPM
  • Wet Weight: 1,110 lb. (505 kg)
  • Seat Height: 26.2 in. (665 mm)
2023 Harley Davidson Freewheeler Specifications​
Engine114 cu in, Milwaukee-Eight® 114
Engine Torque122 ft-lb
Bore x Stroke4.016 in.X 4.5 in.
Compression Ratio
10.5:1
Starter
ExhaustShorty slash down-style chrome finish mufflers
Clutch
Transmission6-speed
Primary Drive
Chain, 34/46 ratio
Front Fork
49mm dual bending valve
Rear Shocks
Hand-adjustable emulsion rear suspension
Wheels, Front Type
Cast Aluminum
Wheels, Rear Type
Cast Aluminum
Brakes Front
32mm 4 piston fixed Dual floating rotors
Brakes RearFloating 36mm piston integrated park brake
Tires Front
MT 130/60B19 M/C 61H
Tires Rear
P215/45R18 83T
Fuel Tank Capacity6 gal.
ColorVivid Black, White Sand Pearl, Bright Billiard Blue/Billiard Gray
Ignition
HeadlightAll LED headlamp
Length
103 in.
Trail
3.96 in.
Rake26
Wheelbase
65.7 in.
Ground Clearance
4.9 in.
Seat Height
26.2 in.
Weight, As Shipped
1,074 lb
Warranty
2023 Harley Davidson Freewheeler Features​
SADDLE UP IN COMFORTTHROW IT IN REVERSE​
Electric reverse gear makes it easier to move vehicle in and out of parking spaces or a garage.
TRUNK SPACE​
Weather-proof rear trunk with top-mounted door for easy loading.
REAR VIEW​
Bobtail rear fenders and slash cut pipe for extra attitude.
BLACKED-OUT STYLING​
Soaking in blacked-out attitude from the front end, headlamp nacelle, tank console, hand and foot controls to the powertrain and exhaust.
Built on a chassis engineered by Harley-Davidson exclusively for three-wheeled vehicles that offers optimized handling and performance.
2023 Harley Davidson Freewheeler Photos​
2023 Harley Davidson Freewheeler 2023 Harley Davidson Freewheeler 2023 Harley Davidson Freewheeler 2023 Harley Davidson Freewheeler
2023 Harley Davidson Freewheeler Videos​
2023 Harley Freewheeler
Big problem on Harley Davidson Freewheeler | Road Glide 3
The post 2023 Harley Davidson Freewheeler [Specs, Features, Photos] appeared first on webBikeWorld.
