The 2023 Harley Davidson Sportster S: Born To Perform
The 2023 Harley Davidson Sportster S comes into 2023 largely unchanged. Part of the Sport section of HD’s 2023 lineup, the Sportster S is the choice if you need your arms stretched or some corners shredded.
The Revolution Max 1250T engine is a liquid-cooled V-Twin putting out 121hp, and making melodious noise through the high-mounted exhaust. Everything about the Sportster S design lets riders know that this Harley is serious about performance.
The Sportster S comes equipped with all the latest technology, including a digital dashboard that provides riders with real-time information on their speed, RPMs, and fuel levels. It also features LED lighting, selectable rider modes, and lean-sensitive ABS and traction control.
And you thought American iron was only fun in straight lines?
3 color choices exist for the 2023 Harley Davidson Sportster S: Vivid Black, Gray Haze, Bright Billiard Blue, and White Sand Pearl.
The 2023 Harley Davidson Sportster S starts at $16,399 USD / $19,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Sportster S in one place.
- Price: $16,399 USD / $19,499 CAD
- Revolution Max Engine
- High Mount Exhaust
- Selectable Rider Modes
- Lean-Sensitive ABS and Traction Control
- Engine: 1,252 cc V-twin
- Power: 121 HP / 90 kW @ 7500 rpm
- Torque: 94 ft-lb (127 Nm)
- Wet Weight: 502 lb. (228 kg)
- Seat Height: 30.1 in. (765 mm)
- Ducati Diavel 1260 S
- Indian FTR S
- Suzuki M109R
2023 Harley Davidson Sportster S Specifications
Engine | 1,252 cc V-twin, Revolution® Max 1250T |
Engine Torque | 94 ft-lb |
Bore x Stroke | 4.134 in. x 2.846 in |
Compression Ratio | 12.0:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Exhaust | 2-into-1-into-2; catalyst in muffler |
Clutch | |
Transmission | 6-speed |
Primary Drive | Gear, 49/89 ratio |
FRONT FORK | 43 mm inverted fork with compression, rebound and spring preload adjustability. Aluminum fork triple clamps. |
REAR SHOCKS | Linkage-mounted, piggyback monoshock with compression, rebound and hydraulic spring preload adjustability |
Brakes Front | radially mounted, monoblock, 4-piston caliper |
Brakes Rear | floating, single piston caliper |
Front Tires | 160/70R17 73V |
Rear Tires | 180/70R16 77V |
Fuel Tank Capacity | 3.1 gal |
Color | Vivid Black, White Sand Pearl,Gray Haze, Bright Billiard Blue |
Ignition | |
Headlight | All LED headlamp |
Tail Light | LED |
Length | 89.4 in. |
Trail | 5.8 in |
Rake | 30 |
Wheelbase | 59.8 in. |
Ground Clearance | 3.5 in. |
Seat Height | 28.9 in |
Weight, As Shipped | 487 lb. |
Warranty | |
Extension |
2023 Harley Davidson Sportster S Features
HIGH EXHAUST MOUNT
Inspired by the glory days of H-D flat-track racing, the pipes are crafted from corrosion-resistant 304-series stainless steel and engineered to deflect exhaust heat away from the rider’s legs and tail section.INSTRUMENTATION
Everything you need to know is housed in a Bluetooth-equipped, 4” round thin-film transistor LCD display: digital gauges, indicators, ride modes, and turn-by-turn navigation with the Harley-Davidson app. All functions are accessed via buttons on the left- and right-hand controls.CHASSIS
The Revolution Max 1250T is a structural component of the motorcycle chassis, eliminating a traditional frame — which significantly reduces overall weight and keeps handling precise. This is performance you can feel, with the center of gravity low and the chassis super rigid.[/accordion
2023 Harley Davidson Sportster S Photos
2023 Harley Davidson Sportster S Videos
What they’re not telling you about the New Sportster S Harley
My 1st BIKE is 1250cc Harley Davidson Sportster S 2023
Harley-Davidson Official Websites
The post 2023 Harley Davidson Sportster S [Specs, Features, Photos] appeared first on webBikeWorld.
