2023 Harley Davidson Street Bob 114 [Specs, Features, Photos]
The 2023 Harley Davidson Street Bob 114: All New
The Street Bob 114 is a staple in the 2023 Harley Davidson lineup and receives no changes this year, except for a new color and a new price. Stripped down for less weight, and raked for a responsive ride, this Softail is ready for aggressive riding. The Street Bob has the power to match the look thanks to the Milwaukee-Eight® 114 engine, the largest engine HD has for the Softail frame.
The perfect badass vibe is created by the combination of blacked-out finishes, black Annihilator cast aluminum wheels, and a pair of little apes. Without a spectacular paint job, no American-made motorcycle is complete, and the HD design team delivers. The fresh color for 2023 is Industrial Yellow paired with the iconic “Number One” insignia on the fuel tank.
3 Color choices for the 2023 Harley Davidson Street Bob 114: Vivid Black, Redline Red, and Industrial Yellow.
The 2023 Harley Davidson Street Bob 114 starts at $16,599 USD / $19,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Street Bob 114 in one place.
2023 Harley Davidson Street Bob 1142023 Harley Davidson Street Bob 114
  • Price: $16,599 USD / $19,999 CAD
    • Milwaukee-Eight® 114 V-Twin engine
    • Softail Frame
    • High-Performance Rear Monoshock
  • Engine: 114 ci V-twin
  • Power: 100.5 HP (estimated)
  • Torque: 119 lbs-ft @ 3000 RPM
  • Wet Weight: 659 lbs (299 kg)
  • Seat Height: 25.8 inches (680 mm)
2023 Harley Davidson Street Bob 114 Specifications​
Engine114 ci V-twin, Milwaukee-Eight® 114
Engine Power100.5 HP (estimated)
Bore x Stroke4.016 in x 4.5 in.
Compression Ratio
10.5:1
Exhaust2-into-2 offset shotgun; catalyst in muffler
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
Dual-bending valve 49 mm telescopic with aluminum fork triple clamps; dual rate spring; gaiter covers
Rear Fork
Hidden, free piston, coil-over monoshock; 43mm stroke; cam-style preload adjustment
Wheels, Front Type
Black, Annihilator cast aluminum
Wheels, Rear Type
Brakes Front
4-piston fixed front
Brakes Rear2-piston floating rear
Tires Front
100/90B19,57H,BW
Tires Rear
150/80B16,77H,BW
Fuel Tank Capacity3.5 gal.
ColorVivid Black w/Cast Wheel, Redline Red w/Cast Wheel, Industrial Yellow w/ Cast Wheels
Ignition
HeadlightHigh beam
Length
91.3 in.
Trail
6.2 in.
Rake30
Wheelbase
64.2 in.
Ground Clearance
4.9 in.
Seat Height
25.8 in.
Weight, As Shipped
631 lb.
Warranty
2023 Harley Davidson Street Bob 114 Features​
LED FORWARD LIGHTING​
Cut through the night with a powerful, adjustable LED front headlamp.
TWO UP, SET UP​
Seating for two with passenger pegs and pillion.
ANNIHILATOR CAST WHEELS​
The 6-spoke design commands attention with fierce lines adding to the custom look of this bike. Steel laced wheels are optional.
2023 Harley Davidson Street Bob 114 Photos​
2023 Harley Davidson Street Bob 114 2023 Harley Davidson Street Bob 114 2023 Harley Davidson Street Bob 114 2023 Harley Davidson Street Bob 114
2023 Harley Davidson Street Bob 114 Videos​
2023 Harley-Davidson Street Bob 114: THE BEST OF LIGHTEST-WEIGHT SOFTAIL
2023 Harley Davidson Street Bob Test Ride – First Impressions
The post 2023 Harley Davidson Street Bob 114 [Specs, Features, Photos] appeared first on webBikeWorld.
