Chase The Wind With The 2023 Indian Pursuit Limited
If you’re in the market for a powerful American touring motorcycle, the 2023 Indian Roadmaster Limited is worth considering. With a starting price of $30,999 US MSRP, the Roadmaster Limited boasts a liquid-cooled V-twin PowerPlus engine that delivers unparalleled low-end torque and top-end passing power. The bike’s chassis-mounted fairing, cast-aluminum frame, and inverted front forks provide rock-solid stability, while optional electronically adjustable Fox rear suspension ensures ultimate control.
As in other models in the 2023 Indian lineup, the Roadmaster Limited also boasts cutting-edge technology that includes built-in audio, cruise control, keyless ignition, and a 7-inch touchscreen powered by RIDE COMMAND with Apple CarPlay integration and turn-by-turn navigation. The touchscreen also features RIDE COMMAND+ connected features, like live weather and traffic overlays, which make it easier to stay connected and safe on the road.
Indian Motorcycles are known for comfort and it’s featured front and center on the Roadmaster Limited. The frame-mounted fairing provides exceptional wind protection, and the vent in the lowers can be adjusted to suit your preferences. The two-up configuration also features optional heated seats that will keep both the rider and passenger comfortable on long rides.
If you opt for the Premium Package, you’ll get even more features, including electronically adjustable rear suspension preload, premium driving lights, and additional storage compartments integrated into the lower fairings. The rider and passenger also get heated seats with premium style that can be adjusted via controls on the seat or the infotainment screen.
The 2023 Indian Pursuit Limited starts at $39,999USD/$38,199 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Indian Pursuit Limited in one place.
Motorcycle Overview
- Price: $39,999USD/$38,199 CAD
- PowerPlus Liquid-cooled engine
- 7 inch RIDE COMMAND touchscreen.
- Chassis mounted fairing
- Inverted forks and Fox rear suspension
- Engine: 1,768 cc, liquid-cooled PowerPlus V-Twin
- Power: 122 horsepower
- Torque: 128 lb-ft
- Weight: 877 lbs (398 kgs)
- Seat Height: 26.5 inches (672 mm)
2023 Indian Pursuit Limited Specifications
Engine | 1768 cc, Liquid-cooled PowerPlus |
Engine Power | 128 ft-lbs |
Bore x Stroke | 4.251 in x 3.799 in (108 mm x 96.5 mm) |
Compression Ratio | 11.0:1 |
Fuel System | Closed loop fuel Injection/ 52mm dual bore |
Exhaust | Split Dual Exhaust w/ Resonator |
Clutch | Wet, Multi-Plate, Assist |
Transmission | 6 Speed |
Final Drive | 2.379:1 |
Suspension Front | 43mm, Inverted Telescopic Fork |
Suspension Rear | Fox Single Shock w/Hyd adjust |
Brakes Front | Dual / 300 mm Semi-Floating Rotor / 4 Piston Radial Caliper |
Brakes Rear | Single / 298mm Floating Rotor / 2 Piston Caliper |
Tires Front | Metzeler Cruisetec 130/60B19 66H |
Tires Rear | Metzeler Cruisetec 180/60R16 80H |
Fuel Tank Capacity | 6.0 gal (22.7 L) |
Color / Graphics | Black Metallic, Spirit Blue Metallic, Maroon Metallic/Crimson Metallic |
Ignition | |
Headlight | LED Headlamp |
Tail Light | LED Taillight |
Overall Length | 102.7 in / 2609 mm |
Overall Width | 39 in (990 mm) |
Overall Height | 56.8 in (1,444 mm) |
Wheelbase | 65.7 in (1668 mm) |
Ground Clearance | 5.4 in (137 mm) |
Seat Height | 26.5 in (672 mm) |
Weight (Empty Tank / Full of Fuel) | 877 lbs (398 kg) / 912 lbs (413 kg) |
Warranty | 2 Years, Unlimited Miles |
Extension |
2023 Indian Pursuit Limited Features
American V-twin Touring Reimagined
This chromed-out powerhouse redefines American touring performance. It’s ready for any route you can dream up.THE ULTIMATE LUXURY
Both the rider and passenger get a heated seat with premium style. Adjust to your preference with controls on the seat, or from your infotainment screen.UNSURPASSED HANDLING
Electronically adjustable rear suspension preload lets you optimize suspension setting based on exactly who you’re riding with and what you’re hauling. Plus, Smart Lean Technology uses a Bosch Inertial Measurement Unit to tune traction control, ABS, and torque for even more control.BRIGHTER, BOLDER LIGHTING
Along with aggressive running lights and an LED headlight, you also get premium driving lights integrated in the lowers.Even More Storage
Enjoy even more storage with additional compartments seamlessly integrated into the lower fairings.2023 Indian Pursuit Limited Photos
2023 Indian Pursuit Limited Videos
2023 Indian Pursuit Limited Review by Ridge Roamer:
2023 Indian Pursuit Limited review by We Ride 2:
The post 2023 Indian Pursuit Limited [Specs, Features, Photos] appeared first on webBikeWorld.
