2023 Indian Pursuit Dark Horse [Specs, Features, Photos]
Experience Luxury On The Open Road With The 2023 Indian Pursuit Dark Horse
The 2023 Indian Pursuit Dark Horse, a luxury touring motorcycle that redefines the American V-twin performance genre. At the heart of the Indian Pursuit Dark Horse is the liquid-cooled V-twin PowerPlus motor, which produces a massive 122 horsepower and 128 ft-lbs of torque. The Pursuit Dark Horse boasts massive stability with its chassis-mounted fairing, optional electronically adjustable Fox® rear suspension, inverted front forks, and a cast-aluminum frame.
Taking cues from other bikes in the 2023 Indian Motorcycle lineup In terms of cutting-edge technology, the Pursuit is equipped with cruise control, built-in audio, keyless ignition, and a 7-inch touchscreen with Apple CarPlay®, Bluetooth®, and RIDE COMMAND+ connected features like live weather and traffic. Showing the way is the bright and bold LED lighting, with LED running lights
Comfort is a priority on the Indian Pursuit Dark Horse and something the Indian Motorcycle brand does well, with a frame-mounted fairing that offers exceptional wind protection. Riders can adjust the vents in the lowers or simply push a button to move the windshield for added convenience. The two-up configuration with available heated seats ensures that both the rider and passenger will be comfortable during long journeys. Speaking of long journeys, with over 35 gallons of weatherproof, remote-locking storage, the Indian Pursuit Dark Horse is ready to carry all the gear needed for extended adventures. For shorter rides, the quick-release trunk can be easily removed to change the motorcycle’s profile and reduce weight.
The 2023 Indian Pursuit Dark Horse starts at $31,999USD/$39,399 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Indian Pursuit Dark Horse in one place.
2023 Indian Pursuit Dark Horse2023 Indian Pursuit Dark Horse
Motorcycle Overview​
  • Price: $31,999USD/$39,399 CAD
    • PowerPlus Liquid-cooled engine
    • 7 inch RIDE COMMAND touchscreen.
    • Chassis mounted fairing
    • Inverted forks and Fox rear suspension
  • Engine: 1,768 cc, liquid-cooled PowerPlus V-Twin
  • Power: 122 horsepower
  • Torque: 128 lb-ft
  • Weight: 877 lbs (398 kgs)
  • Seat Height: 26.5 inches (672 mm)
2023 Indian Pursuit Dark Horse Specifications​
Engine1768 cc, Liquid-cooled PowerPlus
Engine Power128 ft-lbs
Bore x Stroke4.251 in x 3.799 in (108 mm x 96.5 mm)
Compression Ratio11.0:1
Fuel SystemClosed loop fuel Injection/ 52mm dual bore
ExhaustSplit Dual Exhaust w/ Resonator
ClutchWet, Multi-Plate, Assist
Transmission6 Speed
Final Drive2.379:1
Suspension Front43mm, Inverted Telescopic Fork
Suspension RearFox Single Shock w/Hyd adjust
Brakes FrontDual / 320mm Semi-Floating Rotor / 4 Piston Radial Caliper
Brakes RearSingle / 298mm Floating Rotor / 2 Piston Caliper
Tires FrontMetzeler Cruisetec 130/60B19 66H
Tires Rear
Metzeler Cruisetec 180/60R16 80H
Fuel Tank Capacity6.0 gal (22.7 L)
Color / GraphicsBlack Smoke, Stealth Gray, Silver Quartz Smoke, Stryker Red Metallic / Black Metallic
Ignition
HeadlightLED Headlamp
Tail LightLED Taillight
Overall Length102.7 in / 2609 mm
Overall Width39 in (990 mm)
Overall Height56.8 in (1,444 mm)
Wheelbase65.7 in (1668 mm)
Ground Clearance5.4 in (137 mm)
Seat Height26.5 in (672 mm)
Weight (Empty Tank / Full of Fuel)
877 lbs (398 kg) / 912 lbs (413 kg)
Warranty2 Years, Unlimited Miles
2023 Indian Pursuit Dark Horse Features​
AMERICAN V-TWIN TOURING REIMAGINED​
The next generation of American touring performance, with an aggressive blacked-out finish to match.
A BIG MOTOR WITH BIG TORQUE​
You’ll crush miles with unimaginable low end torque right off the line and exhilarating top end passing power from the liquid-cooled V-twin PowerPlus motor.
ROCK SOLID STABILITY​
With a chassis-mounted fairing, with optional electronically adjustable Fox rear suspension, inverted front forks, and a cast-aluminum frame, you have the ultimate control.
CUTTING EDGE TECHNOLOGY​
Cruise control, built in audio, keyless ignition and even more ride enhancing tech are combined with a 7 in touchscreen. The touchscreen is powered by RIDE COMMAND with Apple Carplay Integration, turn-by-turn navigation, and RIDE COMMAND+ connected services like live traffic and weather overlays
UNSURPASSED COMFORT​
The frame-mounted fairing provides exceptional wind protection on its own. For even more, adjust the vents in the lowers or simply push a button to send up the windshield. While it’s considerate to check in on a passenger when you have one, you don’t really need to: In this two-up configuration with optional heated seats, they’ll be just as comfortable as you.
High-output speakers in the fairing and trunk deliver 200-watts of crystal-clear audio. It also sports a dynamic equalizer that automatically adjusts for road, wind and engine noise.
LONG-HAUL STORAGE​
More than 35 gallons of weatherproof, remote-locking storage can handle all the gear you’ve got. Or take off the quick-release trunk to drop weight and give yourself a whole new profile.
BRIGHT, BOLD LIGHTING​
You won’t go unnoticed, thanks to LED running lights and a LED headlight with menacing style.
2023 Indian Pursuit Dark Horse Photos​
2023 Indian Pursuit Dark Horse 2023 Indian Pursuit Dark Horse 2023 Indian Pursuit Dark Horse 2023 Indian Pursuit Dark Horse
2023 Indian Pursuit Dark Horse Videos​
2023 Indian Pursuit Dark Horse Review by Chasing Trail:
2023 Indian Pursuit Dark Horse review by Finesse The Challenger:
Indian Motorcycle Official Websites​
The post 2023 Indian Pursuit Dark Horse [Specs, Features, Photos] appeared first on webBikeWorld.
