2023 Kawasaki Ninja 650 [Specs, Features, Photos]
The 2023 Kawasaki Ninja 650 Is A Competent Middleweight
For 2023, Kawasaki‘s Ninja 650 emerges as a contender in the middle weight category. This machine combines a compact 649cc parallel-twin, 68 horsepower engine with a lightweight trellis frame, yielding an exhilarating yet accessible riding experience. With a comfortable, rider-friendly ergonomics, it’s an ideal choice for both daily commuting and spirited weekend jaunts. The 650’s capabilities are highlighted by its sleek styling which mirrors the aggressive character of other bikes in Kawasaki’s Ninja family. Integrated within this aerodynamic design is a modern LED headlight, adding both function and form.
The motorcycle’s instrumentation is equally contemporary, boasting a full-color 4.4 inch TFT display that offers smartphone connectivity via Kawasaki’s RIDEOLOGY THE APP. The Ninja 650’s powertrain is optimized for smooth, linear power delivery, ensuring responsive low- to mid-range torque. The Assist and Slipper Clutch facilitates seamless shifts, while the Dunlop Sportmax Roadsport 2 tires provide superior grip and confidence on the road.
In terms of suspension, the Ninja 650 utilizes a 41mm telescopic fork in the front and a horizontal back-link rear suspension, both adjustable for preload, allowing riders to fine-tune their ride according to personal preference and road conditions. Braking duties are handled by Nissin components, with dual 300mm front discs and a single 220mm rear disc, ensuring reliable stopping power. The Ninja 650 is a well-rounded motorcycle that combines performance, style, and comfort in an accessible package for both new and experienced motorcyclists. It competes quite well with others in the middleweight category of Japanese motorcycles and makes it a top choice.
The 2023 Kawasaki Ninja 650 starts at: $7,999 USD/$9,699 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Ninja 650 in one place.
2023 Kawasaki Ninja 6502023 Kawasaki Ninja 650
  • Price: $7,999 USD/$9,699 CAD
    • Twin LED headlights
    • Windshield and upper cowl
    • Traction control
    • Horizontal Back-Link Rear Suspension
  • Engine: 649cc, 4-stroke, Parallel Twin, DOHC, 8-valve, liquid cooled
  • Power: 68 horsepower
  • Torque: 47.2 lb-ft
  • Weight: 419 lbs (207 kgs)
  • Seat Height: 31.1 inches (790 mm)
2023 Kawasaki Ninja 650 Specifications​
Engine649cc, 4-stroke, Parallel Twin, DOHC, 8-valve, liquid cooled
Power68 hp
Bore x Stroke83.0 x 60.0mm
Compression Ratio
10.8:1
Fuel SystemDFI® with dual 36mm Keihin throttle bodies
Lubrication
Clutch
Transmission6-speed
Final DriveSealed chain
Suspension Front41mm hydraulic telescopic fork/4.9 in
Suspension RearHorizontal back-link with adjustable spring preload/5.1 in
Brakes FrontDual 300mm petal-type discs and 2-piston calipers and ABS
Brakes Rear
Single 220mm petal-type disc and single-piston caliper and ABS
Tires Front
120/70×17
Tires Rear160/60×17
Fuel Tank Capacity4.0 gal
Color
Metallic Matte Graphenesteel Gray/Ebony, Pearl Robotic White/Metallic Matte Flat Raw Graystone/Ebony
IgnitionTCBI with electronic advance
HeadlightLED
Overall Length80.9 in
Overall Width29.1 in
Overall Height45.1 in
Wheelbase55.5 in
Ground Clearance5.1 in
Seat Height31.1 in
Curb Weight419.0 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12, 24, 36 or 48 months
2023 Kawasaki Ninja 650 Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
2023 Kawasaki Ninja 650 Photos​
2023 Kawasaki Ninja 650 2023 Kawasaki Ninja 650 2023 Kawasaki Ninja 650 2023 Kawasaki Ninja 650
2023 Kawasaki Ninja 650 Videos​
2023 Kawasaki Ninja 650review by Arch417 Powersports:
2023 Kawasaki Ninja 650 Review by Overdrive:
Kawasaki Official Websites​
The post 2023 Kawasaki Ninja 650 [Specs, Features, Photos] appeared first on webBikeWorld.
