MV Agusta: Affordable Adventure on Two Wheels
The Brutale RR is the “starter” version of MV Agusta’s 2023 naked bike lineup. This motorcycle embodies the perfect blend of power, elegance, and advanced technology. Italian motorcycle marques are known for their style and MV doesn’t disappoint with its glossy Fire Red and Intense Black finishes that make it a standout on the road, attracting both curious eyes and avid motor enthusiasts alike.
Running this beast is a 3-cylinder engine that delivers a whopping 140 horsepower at 12,300 RPM. The 798cc engine displacement ensures an exhilarating ride, while the dry weight of about 385.8 pounds keeps the bike agile and easy to maneuver. The motorcycle’s power and torque are not only felt but also heard. The RR symbolizes this promise with a more efficient exhaust system and redesigned injectors to ensure better fuel atomization.
The latest generation electronics shown in multiple bikes in MV Agusta’s Brutale family including the new IMU inertial platform, developed exclusively for the brand redefines the standards of electronic controls. Traction control is more precise than ever, while the FLC wheelie control lets you explore the limits while still keeping you out of trouble. The new EAS 3.0 electronic gearbox offers improved precision and speed.
Control is top of the list with all that power on tap. The new Continental ABS ensures that even the sharpest and most sudden maneuvers can be made with ease. It includes a cornering function that enables safe braking even on corners, interfacing with the inertial platform designed specifically for the Brutale range.
The 2023 MV Agusta Brutale RR starts at $19,998 USD/$21,548 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 MV Agusta Brutale RR in one place.
- Price: $19,998 USD/$21,548 CAD
- Powerful 798cc 3-cylinder, 140 horsepower engine
- Twin-piston floating caliper with 300mm disc.
- Minimalist design and instruments
- Adjustable rear suspension
- Engine: 798 cc 3 cylinder, 4 stroke, 12 vale
- Power: 140 horsepower
- Torque: 63 ft-lbs
- Weight: 385 lbs (175 kgs)
- Seat Height: 32.68 inches (845 mm)
2023 MV Agusta Brutale RR Specifications
Engine | 798 cc, Three cylinder, 4 stroke, 12 valve |
Power | 140 Hp |
Bore x Stroke | 79 mm x 54.3 mm (3.1 in. x 2.1 in.) |
Compression Ratio | 13.3:1 |
Timing system | “D.O.H.C” with mechanical chain tensioner and DLC tappet |
Color | Bianco Surreale, Rosso Fudoco, Nero Intenso |
Clutch | Multi-disc wet clutch with hydraulic actuation and back torque limiting device |
Transmission | Cassette style; six speed, constant mesh |
Final Drive Ratio | 16/41 |
Suspension Front | Marzocchi “UPSIDE DOWN” aluminium telescopic hydraulic fork with DLC treatment, anodized fork legs and having rebound- compression damping and spring preload external and separate adjustment |
Suspension Rear | Progressive Sachs single shock absorber with rebound and compression damping and spring preload adjustment |
Brakes Front | Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange |
Brakes Rear | Single steel disc with Ø 220 mm (Ø 8.66 in.) dia. |
Tires Front | 120/70 – ZR 17 M/C (58 W) |
Tires Rear | 180/55 – ZR 17 M/C (73 W) |
Fuel Tank Capacity | 16.5 l (4.36 U.S. gal.) |
ABS System | Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function |
Battery | 12 V – 8.5 Ah |
Voltage | 12 V |
Alternator | 350 W at 5000 r.p.m. |
Headlight | |
Tail Light | |
Overall Length | 2045 mm (80.51 in.) |
Overall Width | 875 mm (34.45 in.) |
Trail | 103.5 mm (4.07 in.) |
Wheelbase | 1400 mm (55.12 in.) |
Ground Clearance | 135 mm (5.31 in.) |
Seat Height | 830 mm (32.68 in.) |
Dry Weight | 175 kg (385,80 lbs.) |
Warranty | |
Extension |
2023 MV Agusta Brutale RR Features
Electronics
The new IMU inertial platform, developed exclusively for MV Agusta, has redefined the standards of quality for electronic controls: traction control is more precise than ever, while FLC wheelie control heightens the thrill of riding without sacrificing any safety. The new EAS 3.0 electronic gearbox offers improved precision and speed.Technology
Standout features start with the steel trellis tube frame with side plates that ensure significant lateral and longitudinal stiffness. The rear lever showcases the progressive suspension, for real sports riding excitement. Without forgetting comfort, which increases with the new seat, updated in both its shape and materials.Safety
The Brembo M4.32 callipers introduced on the Brutale RR are lightweight and very stiff – the braking power increases along with the ease of use, while the weight drops by 200 grams. The Continental MK100 ABS with RLM and cornering function allows for safe braking, even through the turns.2023 MV Agusta Brutale RR Photos
2023 MV Agusta Brutale RR Videos
2023 MV Agusta Brutale RR Review by R1dealong:
2023 MV Agusta Brutale RR review by The Bike Show:
MV Agusta Websites
Other Links
The post 2023 MV Agusta Brutale RR [Specs, Features, Photos] appeared first on webBikeWorld.
