2023 MV Agusta Superveloce 800 [Specs, Features, Photos]
2023 MV Agusta SuperVeloce: Power, Control, and Elegance Combined
From the heart of Italy, MV Agusta has once again delivered an impressive display of craftsmanship and engineering prowess with the SuperVeloce. Packed with power, advanced technology, and exquisite design, this bike not only meets expectations but soars beyond them. Italian motorcycles are known for their style and MV’s continued use of the single sided swingarm and sculpted bodywork reinforces that.
Powering this masterpiece is a 798 cc, three-cylinder, four-stroke, 12-valve engine putting out 147 horsepower. The SuperVeloce manages to keep this energy in check with an advanced ignition – injection system. It’s equipped with the second generation of the Motor & Vehicle Integrated Control System (MVICS 2.1), which provides excellent control with six injectors and a full ride-by-wire throttle body. This bike is smart, with ion-sensing technology to monitor and control detonation and misfire, four maps for torque control, and an impressive eight levels of traction control intervention
Also found on other bikes in MV Agusta’s 2023 lineup is a wet, multi-disc slipper clutch and a six-speed, constant mesh transmission, providing smooth gear shifts and a seamless riding experience. To top it off, the SuperVeloce also comes with an Electronically Assisted Shift Up & Down feature (MV EAS 3.0) for a lightning-quick shifting experience
Containing all this power and performance is an ALS Steel tubular trellis frame that provides the necessary rigidity and lightness to enhance handling and control. The bike also features aluminum alloy swing arm pivot plates and a single-sided swing arm made of the same material. The SuperVeloce is equipped with Marzocchi upside down forks at the front and a Progressive Sachs single shock absorber at the rear.
For braking, the SuperVeloce features a double floating disc with a 12.6-inch diameter at the front and a single steel disc with an 8.66-inch diameter at the rear. Both front and rear brakes use Brembo calipers, ensuring impressive stopping power and control. The bike also includes a Continental MK100 ABS system with Rear Wheel Lift-up Mitigation and a cornering function, enhancing safety and confidence during spirited rides while the Pirelli Corsa tires keep you stuck to the tarmac.
The 2023 MV Agusta Superveloce 800 starts at $27,899 USD/$29,899 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 MV Agusta Superveloce 800 in one place.
2023 MV Agusta Superveloce 8002023 MV Agusta Superveloce 800
  • Price: $27,899 USD/$29,899 CAD
    • Radial 4 piston calipers
    • 4 engine maps with 1 customizable
    • LED lighting
    • MVICS control system with 6 injectors
  • Engine: 798 cc 4 Cylinder
  • Power: 147 horsepower
  • Torque: 64 ft-lbs
  • Weight: 381 lbs (173 kgs)
  • Seat Height: 32.63 inches (830 mm)
2023 MV Agusta Superveloce 800 Specifications​
Engine798 cm3 (48.7 cu. in.), Three cylinders, 4 stroke, 12 valves
Power147 Hp
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio13.3:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
ColorGrigio Nardo, Nero Carbon Metallizzato, Opaco, Rosso Ago
ClutchWet, multi-disc slipper clutch
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio17/43
Suspension FrontMarzocchi “upside-down” telescopic hydraulic fork with TiN low friction treatment; external compression, rebound and spring preload adjustment.
Suspension RearProgressive, Sachs single shock absorber with rebound and compression damping and spring preload adjustment
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear180/55 – ZR 17 M/C (73 W)
Fuel Tank Capacity16,5 l (4.36 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 8.6 Ah
Voltage12 V
Alternator350 W at 5.000 r.p.m.
Headlight
Tail Light
Overall Length2.015 mm (79.92 in.)
Overall Width760 mm (28.74 in.)
Trail99 mm (3.89 in.)
Wheelbase1.380 mm (54.33 in.)
Ground Clearance120 mm (4.72 in.)
Seat Height830 mm (32.68 in.)
Dry Weight173 kg (381.4 lbs.)
Warranty
2023 MV Agusta Superveloce 800 Features​
Electronics​
Sport, Race, Rain, Custom: four modes and as many interpretations of a character that is always bold, but can adapt to a rider’s preferences and the type of road. In addition to three pre-set maps, one is fully customisable.
Technology​
While the exterior of the Superveloce boasts a very classic design, the fairings conceal the most contemporary technological equipment, all condensed into just 173 kg of weight. From the EAS 3.0 quick shift to the advanced inertial platform.
Safety​
The braking system now makes use of prestigious Brembo Stylema M4.30 callipers, which allow for a weight reduction of 300 grams while upping the braking power. The rear brake has also been updated to increase feeling and ease of use.
2023 MV Agusta Superveloce 800 Photos​
2023 MV Agusta Superveloce 800 2023 MV Agusta Superveloce 800 2023 MV Agusta Superveloce 800 2023 MV Agusta Superveloce 800
2023 MV Agusta Superveloce 800 Videos​
2023 MV Agusta Superveloce Review by Motorcycle Sounds and Reviews:
2023 MV Agusta Superveloce review by imKay:
MV Agusta Websites​
Other Links​
The post 2023 MV Agusta Superveloce 800 [Specs, Features, Photos] appeared first on webBikeWorld.
