2023 Suzuki GSX-R600 / R600Z [Specs, Features, Photos]
The 2023 Suzuki GSX-R600 Is A Rowdy Entry To The GSX-R Line
When most people think of an entry-level sport bike, they probably think of a boring detuned, cheapo version of a bigger superbike, but not with the 2023 Suzuki lineup – the baby Gixxer, or GSX-R600 as Suzuki calls it, is not a bike for the faint of heart. It’s an entry-level bike only because it happens to be the smallest unit that carries the legendary GSX-R nomenclature.
At the heart of this little GSX-R is a 104 hp, 44 lb-ft, 599cc inline-four. Weighing in at just 412 lbs, this unit can really pack a big punch into a small package. As with the rest of the GSX-R lineup, the 600cc iteration is a race track-bred machine that can still function as a fantastic street rider. Much of the bike’s technology and engineering is passed down from lessons learned by Suzuki’s now-shuttered MotoGP racing team. Sure this isn’t the prototype ridden by Alex Rins and Joan Mir last season, but the 2023 GSX-R600 is perfectly at home on the race track, sporting a set of Showa Big Piston Front-fork (BPF) inverted front forks and an electronically controlled steering damper, among other race-ready features.
This Japanese-built machine is available in two packages: The base model, and the GSX-R600Z package, a purely cosmetic upgrade which adds on a MotoGP-inspired livery for an additional $100.
The 2023 iteration of this bike is available for purchase in two dual-tone colours in the united states – Pearl Brilliant White / Metallic Matte Stellar Blue and Glass Sparkle Black / Glass Mat Mechanical Gray. Meanwhile, in the Canadian market the GSX-R600 is only availabe in the Black and Gray colour scheme. Both markets also offer the Z package.
The 2023 Suzuki GSX-R600 starts at $11,699 USD / $12,899 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Suzuki GSX-R600 in one place.
2023 Suzuki GSX-R600 / R600Z2023 Suzuki GSX-R600 / R600Z
Motorcycle Overview​
  • Price: $11,699 USD / $12,899 CAD
    • 599cc inline-four
    • Adjustable SHOWA suspension
    • Brembo Brake setup
    • Optional MotoGP livery
  • Engine: 599cc inline-four
  • Power: 104hp
  • Torque: 44 lb-ft
  • Weight: 412 lbs (187 kg)
  • Seat Height: 31.9 inches (810mm)
  • Honda CB600RR
  • Kawasaki Ninja ZX-6R
  • Yamaha R7
  • Aprilia RS660
2023 Suzuki GSX-R600 / R600Z Specifications​
Engine​
Engine599cc, 4-stroke, 4-cylinder, liquid-cooled, DOHC
Bore x Stroke67.0 mm x 42.5 mm (2.638 in. x 1.673 in.)
Compression Ratio12.9:1
Fuel SystemSuzuki Fuel Injection
LubricationWet sump
Drivetrain​
ClutchWet, multi-plate type
Final DriveRK525SMOZ8, 114 links, Chain
Chassis​
Suspension FrontInverted Telescopic, coil spring, oil damped
Suspension RearLink type, coil spring, oil damped
Brakes FrontBrembo, Disc, Twin
Brakes RearDisc
Tires Front120/70ZR17M/C (58W), tubeless
Tires Rear180/55ZR17M/C (73W), tubeless
Fuel Tank Capacity17.0 L (4.5 US gal )
Color
Electrical​
IgnitionElectronic ignition (transistorized)
Spark Plug
Headlight12V 65W (H9 high-beam) and 12V 55W (H7 low-beam)
Dimensions​
Overall Length2,030 mm (79.9 in.)
Overall Width710 mm (28.0 in)
Overall Height1135 mm (44.7 in)
Ground Clearance
Wheelbase1,385 mm (54.5 in.)
Seat Height810 mm (31.9 in.)
Curb Weight187 kg (412 lb.)
Warranty​
Warranty12-month unlimited mileage limited warranty
ExtensionLonger coverage periods with other benefits available through Suzuki Extended Protection (SEP)
2023 Suzuki GSX-R600 / R600Z Features​
SUZUKI PROTECTION PLAN​
Suzuki Protection Plan is a comprehensive plan that covers all mechanical, electrical and computer systems on your Suzuki Motorcycle or ATV. Ask your local Authorized Dealer about Suzuki Protection Plan for extra peace of mind.
CAREFULLY SCULPTED BODYWORK​
Highlights include the powerful lines of the chiseled fuel tank, vented front fender, light rear fender, molded mirrors, and angular tail section with integrated LED taillight, clear turn signals, and clean layout of all wiring and hoses. The thin seat is shaped for sport riding, and also to helps make it easier to firmly plant your feet on ground and combines with the handlebars and footpegs to ensure a comfortable riding position.
STYLING​
Race-ready, iconic GSX-R styling provides sharp looks and a slippery shape with deep, rich paint with monochromatic graphics and color-matched cast aluminum wheels.
RIDING POSITION​
Three-way adjustable foot pegs, adjustable shift lever and short fuel tank help compose a comfortable riding position that permits the rider movement required for performance riding.
A LIGHTER, MORE COMPACT CHASSIS​
The GSX-R600 model features completely chassis designs, each based on a more compact, lighter twin-spar aluminum frame with a 15 mm shorter wheelbase. The GSX-R600’s wheelbase now measures 1,385 mm.
STRONG STOPPING POWER​
Twin Brembo Monobloc, radially-mounted front brake calipers grasp fully floating stainless steel brake rotors to deliver strong stopping power.
ENGINE DESIGN​
A compact 599cc, four-cylinder engine with a race-proven over-square bore/stroke ratio produces remarkably strong high rpm power delivery. The energy-efficient engine employs forged pistons, shot-peened connecting rods, chrome-nitride-coated upper compression and oil control rings, and pentagonal ventilation holes to reduce frictional and mechanical losses.
STEERING DAMPER​
Electronically controlled steering damper provides lighter steering at slower speeds and more damping force at racetrack and highway speeds.
RACING SUSPENSION​
Both the Suzuki GSX-R750 and the Suzuki GSX-R600 come with the revolutionary, race-developed Showa Big Piston Front-fork (BPF) inverted front suspension system. Conventional inverted front forks use a cartridge assembly that fits inside the fork leg on each side and typically incorporates a 20 mm piston to control damping.
EXHAUST SYSTEM​
Four-into-one stainless steel exhaust system with a titanium muffler is fitted with a Suzuki Exhaust Tuning (SET) valve that maximizes torque and improves throttle response, especially in the low- to mid-rpm range.
OPTIONAL FEATURE​
Optional single seat cowl can replace the passenger seat for an even more aggressive look or for use on solo rides or track days.
SUZUKI EMBLEMS​
Stylized Suzuki “S” 3-D emblems on the fuel tank and the fork upper bracket denotes the quality, sophistication, and performance legacy of the brand.
2023 Suzuki GSX-R600 / R600Z Photos​
2023 Suzuki GSX-R600 / R600Z 2023 Suzuki GSX-R600 / R600Z 2023 Suzuki GSX-R600 / R600Z 2023 Suzuki GSX-R600 / R600Z
2023 Suzuki GSX-R600 / R600Z Videos​
Suzuki GSXR600 Review| by AK Cycles:
NEW!! 2023 SUZUKI GSX R-600 by Francis Rabanes:
SUZUKI Motorcycles Websites​
The post 2023 Suzuki GSX-R600 / R600Z [Specs, Features, Photos] appeared first on webBikeWorld.
