The 2023 Triumph Speed Triple 1200 RR: The Statement!
Introduced last year, the Triumph Speed Triple 1200 RR is an absolute statement piece from the famed British motorcycle manufacturer. Largely unchanged coming into the 2023 model lineup, power comes courtesy of a 1160cc, three-cylinder, low-inertia engine making 178 horsepower and 92 lb-ft of torque.
Triumph ensured the RR is the most focused Speed Triple ever, featuring clip-on handlebars and a beautifully crafted fairing. Fitted with the latest Öhlins Smart EC 2.0 electronically adjustable, semi-active forks and rear monoshock, Brembo Stylema brakes, and Pirelli Diablo Supercorsa SP V3 tires, it is clear this Speed Triple is about performance.
The 5” TFT display gives access to the advanced electronic rider aids that enhance performance and safety. Selectable Rider modes, Triumph Shift Assist, Optimized Cornering ABS, and Optimized Cornering Traction Control bring a state-of-the-art safety system for riding in all conditions.
Triumph also offers the Speed Triple 1200 RR Bond Edition. Limited to 60 individually numbered motorcycles, they Celebrate 60 years of Bond and the partnership between 007
2 Color choices for the 2023 Triumph Speed Triple 1200 RR: Red Hopper and Crystal White.
The 2023 Triumph Speed Triple 1200 RR starts at $20,950 USD / $23,250 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Triumph Speed Triple 1200 RR in one place.
- Price: $20,950 USD / $23,250 CAD
- 1160cc Triple engine
- Öhlins Smart EC 2.0 suspension
- Brembo Stylema Brakes
- Triumph Shift Assist up-and-down quick-shifter
- Special 007
- 5 customizable riding modes
- Engine: 1160 cc DOHC, inline 3-cylinder
- Power: 178 HP (estimated)
- Torque: 92 lbs-ft @ 9000 RPM
- Wet Weight: 438 lb (199 kg)
- Seat Height: 32.7 in (830 mm)
- MV Agusta Superveloce S
- Ducati Panigale V2
- Aprilia Tuono V4
2023 Triumph Speed Triple 1200 RR Specifications
Engine | 1160cc, Liquid-cooled, 12 valve, DOHC, inline 3-cylinder |
Power | 177 Hp |
Bore x Stroke | 90.0 x 60.8 |
Compression Ratio | 13.2:1 |
Fuel System | Multipoint sequential electronic fuel injection with electronic throttle control |
Exhaust | Stainless steel 3 into 1 header system with underslung primary silencer and side mounted secondary silencer |
Clutch | Wet, multi-plate, slip |
Transmission | 6-Speed |
Final Drive | X-ring chain |
Suspension Front | Öhlins 43mm fully adjustable USD forks, 120mm travel. Öhlins S-EC 2.0 OBTi system electronic compression / rebound damping |
Suspension Rear | Öhlins monoshock RSU with linkage, 120mm rear wheel travel. Öhlins S-EC 2.0 OBTi system electronic compression / rebound damping |
Brakes Front | Twin 320mm floating discs. Brembo Stylema monobloc calipers, OC-ABS, radial master cylinder with separate reservoir, span |
Brakes Rear | Single 220mm disc. Brembo twin piston caliper, OC-ABS. Rear master cylinder with separate reservoir |
Tires Front | 120/70 ZR 17 (58W) |
Tires Rear | 190/55 ZR 17 (75W) |
Fuel Tank Capacity | 4.1 US gal (15.5 litres) |
Color | |
Ignition | |
Headlight | LED |
Tail Light | LED |
Rake | 23.9 º |
Width Handlebars | 29.84 in (758 mm) |
Height Without Mirror | 44.1 in (1120 mm) |
Wheelbase | 56.65 in (1439 mm) |
Trail | 4.12 in (104.7 mm) |
Seat Height | 32.68 in (830 mm) |
Wet Weight | 438 Lbs |
Warranty | |
Extension |
2023 Triumph Speed Triple 1200 RR RR Features
BLISTERING TRIPLE ENGINE PERFORMANCE
The Speed Triple 1200 RS took the world by storm in January 2021 with its responsive and powerful 177HP, 1160cc, three-cylinder, low-inertia engine. Now, the same compact and lightweight unit powers the Speed Triple 1200 RR giving an even more thrilling Speed Triple riding experience, thanks to its more focused ergonomics and specification upgrades. A brushed stainless-steel exhaust with black end-cap delivers the soundtrack resulting in a perfect pitch.GENUINE SPORTS ERGONOMICS AND HANDLING
Engineered with exquisite attention to detail, the RR is the most focused Speed Triple ever, featuring clip-on handlebars and a beautiful new crafted fairing, giving it a nose-down, aggressive riding position that is pure and sophisticated.Fitted with the latest Öhlins Smart EC 2.0 electronically adjustable, semi-active forks and rear monoshock, the Speed Triple 1200 RR boasts the most advanced production Öhlins suspension available. Race-developed Brembo brakes include a span and ratio adjustable lever, radially-mounted Stylema® monobloc calipers and lightweight 320mm discs. Plus new high-performance Pirelli Diablo Supercorsa SP V3 tires, a lightweight cast aluminum chassis and an optimized center of gravity deliver the new benchmark in Speed Triple precision handling and agility.
PERFORMANCE-ENHANCING TECHNOLOGY
Constant development has transformed rider-aid technology, and the Speed Triple 1200 RR provides the perfect showcase.The Optimized Cornering ABS and Optimized Cornering Traction Control bring a state-of-the-art safety system for riding in all conditions. And the assistance is never intrusive or restrictive, the tipping point between performance and safety is always perfectly balanced.
The standard-fit Triumph Shift Assist up and down quickshifter works superbly at any engine speed and load, optimizing gear shifts while maintaining throttle position, and helping to increase focus on the racetrack or the road. The latest generation front wheel lift control uses advanced algorithms to allow a non-intrusive smooth ride with constant, positive throttle.
LESS EFFORT, MORE FUN
In addition to the advanced electronic rider aids that enhance performance and safety, the Speed Triple 1200 RR features a number of thoughtful ride-enhancing touches.The 5” TFT display has a strong focus on speed, gear and tach, that can be configured to suit the rider’s preference — the information you need to ride on the road is often different to the information you want in your eyeline on the racetrack.
The My Triumph Connectivity System comes as standard, with an integrated Bluetooth module, making phone calls and music to your in-helmet system effortless, along with turn-by-turn navigation and GoPro control. Accessed via easy-to-use handlebar-mounted switch cubes controlling menu systems that are intuitive and user-friendly, all the ride information you need is at your fingertips.
FIVE RIDING MODES
The five riding modes (Rain, Road, Sport, Track and Rider Configurable) can be easily selected on the move, via a dedicated button on the left handlebar. These different modes have been developed through intensive testing to give the perfect throttle response, Traction control and ABS settings to suit a broad range of weather and road conditions. Of course, we all have our own preferences as riders, so the Rider Configurable option allows fine-tuning of each parameter to suit your style.THE PINNACLE IN SPEED TRIPLE ATTITUDE
The new RR takes all the muscular attitude and signature Speed Triple style of the new generation RS and raises it to a whole new level with a host of beautiful features and touches. The Speed Triple’s nose-down muscular broad-shouldered poise and attitude is amplified further by the stunning new crafted cockpit fairing with beautiful single headlight that echoes Triumph’s signature design DNA. Add to that the RR’s exquisite attention to detail, premium carbon fiber detailing and stunning candy paint schemes with Red Hopper and Crystal White options, and you have the pinnacle in Speed Triple attitude and style.2023 Triumph Speed Triple 1200 RR Photos
2023 Triumph Speed Triple 1200 RR Videos
2023 Triumph Speed Triple 1200 RR First Ride | REVIEW
Triumph Speed Triple RR | EVERYTHING You Need To Know
The post 2023 Triumph Speed Triple 1200 RR [Specs, Features, Photos] appeared first on webBikeWorld.
