- Joined
- Jun 12, 2013
- Messages
- 2,900
- Reaction score
- 917
- Points
- 113
- Location
- North Central Florida
I have also seen my best mileage on the Blueridge Parkway and in the Smokies; at 45 mph at those altitudes, I got close to 80mpg.One more consideration is altitude. On fuel injection engines the effect is two fold. When you are cruising down the highway you don't need maximum power and are using minimal throttle. The fuel injection system only gives enough fuel for the oxygen flowing thru the engine. At higher altitudes you have less oxygen in the air so for a given throttle position you are actually using less fuel.
Secondly at higher altitudes you have less air pressure and your wind resistance is less, therefore improving your fuel economy also. This effect is higher than you think.
Living in AZ and traveling throughout the rockies I have seen my best mileage by far at high altitudes.
Sent from my SCH-I545 using Tapatalk
