vinay
Hi there,
so far I don't even have motorcycle but this upcoming Saturday I'm planning to pick up 2020 NC750X which appears to be quite well equipped straight from the factory. In this context in particular, the bike is equipped with the Honda heated grips and their floodlights. I've been digging through the manuals and from what I understand, the Honda heated grips are supposed to be powered by the 6 pin connector so I trust that's also how it has been installed. Thing is, I've got this GPS navigation device which I plan to install once I've got hold of the bike so initially I was planning to order this kit so that I could get going straight away but this one needs the 6 pin connector as well. So that got me wondering, is there still a way to connect electrical accessories or would my only option be to connect it straight to the battery? My concern would be that if I'd do that, the power adaptor might drain the bike battery when the bike is parked and the navigation device is removed.
Obviously I could remove the side panel once I've got the bike but if someone is already running a similar configuration (so the factory installed Honda heated grips) this rider may also be aware of what my options are. In which case I could order the parts I need up front hence be done just a tiny bit quicker. If not, no worries. I'll just wait and pop the side panel next week.
Thanks a lot for looking in this!
