DCT Filter Removal Tool
dduelin
North FL USA
I have found the little DCT filter a little difficult to remove. The temptation is to take a couple of small screwdrivers 180 degrees apart to catch the edges of it and pry it out but I did not want to risk damaging the machined edge of the filter housing.
I took a piece of wire from the handle of Chinese take-out container and bent it to suit the task. The quarter is in the photo for a scale size reference. The tool slips in the small gap between the filter and housing and when turned a little the hook end catches the inner edge of the filter to pull it out.
ST13Fred
Proctor WV USA
Good thinking.
I've had mine off only once but remember it is a cramped area at the filter.
I have a Craftsman 'booger hook' that may also serve as a good pry tool.
T S N
florida
I like the hook idea.
Last time I used my magnetic drain plug to get the filter out.
sumo
SW Ontario
Every toolbox should have this pick set. I find myself using them regularly. Must have.
ld_rider
New England
Small magnet is the easiest method and you might have one laying around already. Mine is on the end of a telescoping rod about 20 inches long when extended and about 4 inches long collapased. About $6 or so. Get one with a strong magnet, otherwise you will have to get a neighborhood kid to give you the magnet out of his old hard drive ;-)
No danger of nicking the bore using the magnet and you can use it to finally fish out those screws you dropped somewhere in the innards of the bike. One of the most go to tools in my box and has saved many a screw from disappearing.
http://www.sears.com/craftsman-magnetic-pick-up-tool/p-00941310000P
Rainier
Central Washington State
Curious if any DCT owners have used the Chinese clone filters from "TC-Motor." Amazon carries them. Search "TC-Motor Oil Filter For 15412-MGS-D21 Honda Motorcycle NC700 S (DCT) Transmission Filter"
I know they're unknown and unknown quality. I do hate paying a premium for a product at the dealer if there's a good aftermarket product that will suffice.
Your thoughts?
DirtFlier
Troy, Ohio
Was the container for Chicken Chow Mein or Sweet & Sour Pork? :p
