backtochain
Experiencing a "repetitious knocking" from the drive sprocket. No matter how aligned the drive sprocket is to the driven sprocket the drive sprocket seems to be binding on the splined shaft. Sprocket splines and shaft splines are in good condition. Another corresponding issue is when spinning the rear tire by hand is there are loose spots and tighter spots with the chain free-play as I spin the tire. The chain is in good condition (no kinks). I am absolutely baffled with this and would appreciate any suggestions.
Thanks , Craig.
Thanks , Craig.
