mblast
Hi guys,
It's my first time using this wonderful forum
I own Honda NC 750XD /2019 model/. The last time when I was going to ride my NC something strange happened. Went to the garage, put it on central stand, started the engine end let it working couple of minutes. When I was ready with my riding gear I sit on the bike and try put it in D (drive), but noting happened. Then I saw a dash sign ( - ) blink in the gear indicator. I shut the engine off with the key and start it again. This time I managed to select Drive mode but MIL (check engine) lamp lights up . I drove couple of kilometers and didn't notice anything unusual with the bike. After the third shut off and start the engine - MIL lamp disappeared. Then I've made a long day trip 500Km in the mountains and the bike feels perfectly fine to me. No more MIL or blinking lamps!
So today I decided to make myself a SCS connector to read the stored error codes. Attached the connector to the diagnostic plug (DLC connector) and With the [+] gear button pressed I turn the ignition key to ON position. Here is the result:
https://streamable.com/sqvctr
Can someone more experienced with DTC readout help me out with the exact DTC codes watching the video?
From what I see the ABS lamp is showing DTC 1-2 (front wheel sensor) or am I wrong? It's hard for me to get the DTC code from the gear indicator lamp also.
Thank you all![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you all
