OK, this farkle is probably only of interest to engineers, gearheads, and inveterate tinkerers. If you are an "If It Isn't Broke, Don't Fix It" type, then please pardon the intrusion and spare yourself the rest of the post. There is no need to tell me that your regulator is working perfectly fine. I am sure that it is.
OK then, what and why? There are three things about the NC's regulator/rectifier set-up that I think can be made better...
1) The R/R is sandwiched between two covers in front of the rear wheel where there is no direct airflow. These things give off a good bit of heat. That is why they are completely covered in cooling fins. Most installation guidance for R/R's says to put them where they can get airflow. So, I think it can be put in a better place to aid its long-term reliability.
2) The connectors used on it are not environmentally shielded. Lots of problems develop in later life when the contacts become corroded and begin to cause local heating.
3) The stock R/R is a Shindengen FH014AA, which is a shunt style regulator. This means that the alternator runs at full output all the time and any excess current is simply shunted to ground. This subjects the alternator stator on a permanent magnet alternator to more stress than is necessary and it dumps the extra heat into the engine oil. On a number of bikes that historically have problems with stator failure, a popular solution is to install a series style R/R in place of the shunt R/R. The series R/R simply opens the alternator circuit when no more electricity is needed. The stator runs cooler, and on those bikes that like to kill stators, they apparently stop doing so.
My thesis is that a series regulator, properly spec'ed and mounted in the airflow with heavy wire and weather-proof connectors should improve the performance and long-term reliability of the entire charging system. When combined with the EarthX ETX36C battery, I think it should be front-to-end an optimized system based on the best currently available technology. In searching for the best 3-phase 30+ amp series R/R I discovered the following:
1) Shindengen makes a series regulator (the SH775) that is plug-and-play compatible with the FH014AA. Even the bolt holes are the same. Though this would be the easiest path and would probably work, it does not solve the problem of location and non-weatherproof connectors. Also, the SH775 is rated at 27 amps where the NC system is rated at 30 amps. I understand that Shindengen has higher amp-rated units under development. EDITED TO ADD (01/25/2016): The higher rated Shindengen regulator is now available. It is part number SH847 and is rated at 50 amps. Simple, but just not an ideal solution. PLEASE SEE POST #23 AND #25 FOR ADDITONAL INFORMATION IF YOU INTEND TO INSTALL THE SH775 IN THE STOCK LOCATION
2) The Compu-fire 55402 is a 40 amp 3-phase R/R and generally meets all of my specs. The construction with electrical leads coming out of the sealed chassis makes the use of weatherproof connectors possible. In researching the reputation of Compu-fire I found that even though they are pretty reliable, that they might be not so generous in the warranty area.
3) The Cycle Electrics CE605SB is the R/R I decided to go with. It is 50 amp rated and about twice the weight of the competition. Made in the good ole USA. Cycle Electrics made their business retrofitting Harley Davidson's trouble-prone regulators and they have earned a great reputation. I have the single phase 30 amp model of this R/R on my BMW R100RS running with an Euromotoelectric permanent magnet alternator. The BMW unit has performed perfectly. The voltage sits at 14.2 like the needle is painted on the voltmeter. Lights on, lights off, 1500 RPM or 5,000 RPM. No change. If this one does as well, I will be a happy camper.
First to extract the stocker. Both side shrouds have to come off for access. While I am at it, I thought I'd show where I chose to hide my spare clutch cable. If it goes "snap" in the middle of nowhere, I have a new one ready to go. I sealed both ends of it so that the internals stay clean...
Then the rear brake reservoir is removed and the rear fender liner is unbolted and moved out of the way. Peek-a-boo!
If thine eye offend thee, pluck it out...
I drilled the mounting holes in my rear luggage rack. The R/R will be mounted underneath the rack...
Next, Delphi Packard Weatherpack connectors were installed (a 3-conductor for the stator leads and a 2-conductor for battery and ground)..
The key to a good installation of open connectors is the right tool. Don't even attempt it without the right crimper...
Here is the finished item...
Here it is in its new home..
Next, the five wires were run through the inner fender area and down to where the R/R was originally located...
Then the connections were made to the bike wiring and everything was tucked back into place...
As a final touch, I replaced the Clearwater CVS LED charge indicator with the Sparkbright model...
So, I started it up and got the 14.2 volts I was looking for but I did not have time today for a test ride. I spent the evening selling my truck. Tomorrow I will give it some road time and see how it performs.
