Not willing that the ABS crowd should have 3-piston calipers when I pnly have two, I ordered an ABS front caliper and pads. The only difference is that the Mark 1 model human being is going to be in charge of all three pots instead of a satellite link to an engineer in Japan who determines if you are about to bust your ass if you squeeze any harder. The first step is to 86 the old system. Always fun and easy....
Next, the ABS caliper was installed along with two Goodridge universal hoses with 15 degree banjos...
Then the original banjo bolt was replaced with a double banjo in order to connect the two hoses to the single master cylinder...
Then it is fill the system and burp out all the air. I was not satisfied with how the hose routing went. In order to make sure I didn't end up with hoses that were too short, I ended up with hoses that are too long. It is amazing how inflexible that flexible hoses can be. I will probably do the hoses over with shorter hose, but for now, it will work until I can get some different ones.
