Neil_S999
NC750S 67 plate.
I have a Givi Top Box and have fitted a pair of LED indicators to it as I wanted high level ones that motorists would see and to also complement the pair of combined rear/brake LED lights which work a treat and increase my visibility. I have tapped into the OEM rear indicators circuit and routed the 4 wires up to the top box (2 live 2 ground). Connected them up and activated the L/H indicator. Lo and behold the L/H LED flashed in sequence with the OEM L/H indicator. So I thought great, just what I wanted. My euphoria was dampened when I activated the R/H indicator as only the OEM one worked. Checked the wiring with a test lamp at the point where the new wiring connected to the LED wires. All OK, the test lamp flashed in sequence with the OEM one. My obvious thought was that the R/H LED is defective. I connected a power supply directly to the R/H LED wires. The R/H LED was not defective. I have ordered a replacement LED compatible indicator relay which has yet to arrive. Any advice would be appreciated as to how I can remedy this.
