vinay
This isn't much of a modification probably, I just installed an oiler and decided to post some pictures here which might be of help to others. I went with the Osco oiler as it doesn't need to be powered, seems well built and it is a brand from The Netherlands (which is where I live) so it may be easier to get hold of spares in case of unfortunatalities. I did connect it to the Scottoiler Scorpion dual injector as that way of applying oil made sense to me. So it turned into a bit of a Frankenoiler.
I chose to install the container onto right hand crash bar. The manual recommends to install it on the right side as this allows you to feather the clutch as you operate the plunger, though I've seen many pictures where it has been installed on the left. Not sure why. Maybe for those with DCT, left would be the way to go though. That said, I honestly don't know what's under the right hand fairing but I do expect to remove the left hand fairing soon to get into the electronics bit so for me it is nice to have that area clear. This location here is fairly easy to reach for both pulling the plunger as well as refilling the container. And yeah, it was raining when I finished the job.
The Scottoiler Scorpion dual injector is a bit harder to see in this image, but it is the fork that applies oil to both sides of the sprocket. This way it gets applied to the inside of the link plates where it hopefully find its way towards the link pins and the inside of the rollers. That's the theory at least. Either way, makes more sense to me that just dripping it onto the center of the chain.
I didn't remove any body panels to guide the hose but I still think I did a fairly nice job. I tried to get a continuously downwards hose routing from the container towards the applicator. My biggest concern was obviously that the hose would rub, get pinched somewhere in the suspension linkage or get snagged as the suspension moves through its travel. Both kits come with more than enough tie-wraps and clamps (where the Osco ones are tighter than the ones from Scottoiler) so when degreased and cleaned, I trust these clamps will stay put and hold the hose in place. I put one underneath the swingarm to keep the hose away from the chain and then guided it towards the inside of the swingarm where I clamped it just next to the rear shock so that it doesn't get touch and rub that one. This is a tighter clamp, so the hose won't slide in that one. In front of this area there seems to be an area where a bunch of cables and hoses pass from left to right so that's what this hose does there as well. I used a tie-wrap to attach it to a thick and stiff bundle of cables (it seems) which keeps it up yet will probably move enough to go with the suspension movement. That said, I think there will be excess hose as it moves through the travel, not a a lack thereof which could jank on the cable. So yeah, I'll keep an eye on it but I trust it will be fine.
