I'm not seeing yet where Ruby said that the pads were replaced.Ruby Rider: Just out of curiosity, did you remove some of the fluid from the reservoir before you fitted the new pads?
Where did you get your new wheels? I'd like to have a spare set but they're quite expensive new. It's difficult to find used wheels in good shape.I feel like I'm going crazy, I went to put my new wheels on today. Everything mounted up just fine. I put on the front caliper and went to build the pressure back up. It won't release. I did have the top of the brake fluid res off but I can't figure it out. I feel incredibly stupid. I've done brake jobs on cars before. I know it's a different machine but the principle is the same.. right?
I didn't replace the pads, I had the calipers off to remount the wheels.Ruby Rider: Just out of curiosity, did you remove some of the fluid from the reservoir before you fitted the new pads?
I got them from cycle gear, it was about 190. Shinko Ravens.Where did you get your new wheels? I'd like to have a spare set but they're quite expensive new. It's difficult to find used wheels in good shape.
Can you explain what pump the forks means?
I want to clarify, I got new tires, not new wheelsI got them from cycle gear, it was about 190. Shinko Ravens.
