mtbmike
Well guys it seems right around the 20,000 mile mark on these bikes the water pump goes kaput its pukeing. Dam never had a water pump fail on any motorcycle that I have owned seems this could be the only week spot of the bike.
It's the only mechanical part I've heard multiple people (multiple being 3 or 4) say was leaking with fairly low miles. It is worth noting no one has had a actual water pump failure that caused any over heating problems just leaking, and at least two fixed it by just changing the gasket on one of the ones I was reading about, the bearing actually was starting to fail and was leaking through the weep holeI've not heard that this is a weak item on the NC700X but what do I know?
why do you anticipate it will happen spell shortly?I'm at 30k and no waterpump leak yet, but I do anticipate it will happen shortly.
Most people are aware, but for those who aren't: Remember, don't merely replace the "gasket" when the waterpump starts to weep. It's designed to weep when it starts to FAIL to let you know to replace it, not to replace the gasket.
I agree if I got 30k I could live with that but I'm at 37 with no problems and there are people with 60 plus that haven't had anything but fluid and filter changesI seem to go through them around this time on most bikes I've owned. I'm mostly tongue-in-cheek when I say I'm expecting it to come along, but I wouldn't be shocked and honestly, at 30k miles, I wouldn't be too upset with it either.
My KTM has a replacement interval of 10k miles, and you have to remove the clutch to get to the waterpump shaft seal. LOL.
