Carwow took a Lamborghini Huracan to the drag strip for a series of straight-line races, but instead of pairing it against another car from its segment, they decided to challenge it with a superbike. The chosen superbike is a Kawasaki H2R, equipped with a supercharged engine and boasting a superior power-to-weight ratio.
The Huracan utilized for the challenge is powered by a 5.2-liter V10 engine, tuned to deliver a whopping 1,100 HP and 1,000 Nm of torque, which is distributed to all four wheels through its all-wheel-drive system. These incredible numbers give the Huracan a power-to-weight ratio of 759 HP per ton.
On the other hand, the Kawasaki H2R is equally impressive in terms of specs, with its 1,000 cc in-line 4-cylinder engine producing 310 HP and 165 Nm of torque.
Will the raw power of the Lamborghini Huracan prevail, or will the superbike’s superior power-to-weight ratio give it the edge? Watch the action unfold to find out!
The post Kawasaki Ninja H2R Takes On A Turbocharged Lamborghini Huracan In A Drag Race appeared first on webBikeWorld.
