tooblekain
- Joined
- Jul 7, 2013
- Messages
- 89
- Reaction score
- 0
- Points
- 6
- Location
- Sandy Eggo, Californication
Finally did the 600 mile oil change for Sofia's bike...Here are my thoughts...
The oil filter is on there waaaayyyy too tight. I had to disconnect the mounts for the coolant overflow and horn to make room to use my oil filter vise grips. The oil filter got destroyed, but didn't crack open. It took forever to remove it. I even had to use penetrating fluid to help with removal of it.
The OEM service manual recommends 30N-m for the oil drain plug. That is the highest I have ever seen for any drain plug for all the cars and bikes I have worked on. I have seen the expensive damage that can happen when tightening the drain plug too tight, so I am going against the OEM service manual and just went with snug (which for me is about 23N-m last time I checked). Ill be sure to check that no oil leaks
