Afan
Brake fluid is hygroscopic, and you cannot tell by looking at it if it is good or bad. Brake fluid is cheap, you are saving pennies but might have to pay dollars later to repair corroded parts. I believe there are testers that measure the resistance or current flow, get one of those instead of depending on its clarity.
All that said, if you live in a very dry area, you might be able to stretch the service intervals.
It's not about 'saving pennies' but rather avoiding unnecessary actions that won't fix my current problem. If there were bubbles in the brake line and I fixed the brake, I would probably replace the fluid because, as you said, once I've opened the canister, I can't keep the fluid for later due to its hygroscopic nature.
Additionally, any service performed to fix the problem, such as replacing the brake line or master cylinder, would require replacing the fluid again anyway, right?
