Blackrider
I traded in my 2009 bmw g650gs for the nc700x., but I had 36,000 miles on mine-got tired of listening to a single. yes, it does have a 1000rpm higher rev limiter but fyi, anything above 2nd gear runs 1000rpms higher than the nc700x, so it is a wash; 4000rpms on the Honda in 6th gear=75mph-on the g650gs, 75mph is somewhere between 5500 and 6000rpms in 5th gear-there is no 6th gear= I hit the rev limiter once on the bmw (80mph in 4th) and have not hit the rev limiter on the honda. To me, both bikes have the same top end, but I think the Honda is faster off the line and accelerates from 70-90mph faster. my g650gs was also black.
Just some hints with the g650gs, with oil changes-all that front plastic has to come off-unless you find a way to siphon the oil out of the oil cooler. all the plastic has to come off for valve checks-every 6000 miles-and bucket/shims and the shims are $$$. In my opinion, the seat on the bmw was even worse than the Honda-more slant but corbin makes a great seat for the bmw-and the seat isn't bolted on-there is a latch under the small rear storage compartment. note-the bmw does not like creek crossings with tourance tires.
good luck with the bmw and hope you have tons of fun.
I'd love to have another NC700x but they only have a red one there and the new ones only come in black and red I think.
I do not like those colors. Plus near $9000 out the door now. Then I have to get my heated grips put back on.
The G650GS is much easier to flick around and has higher gears. I always had to click the NC700 down to 5th to pass
faster on the highway. Hit the rev limiter a lot. Also hit the horn a lot trying for the turn signal because of the way it is situated.
Hauling gear for long trips was troublesome because of the gas cap under the back seat.
Both bikes have negatives and positives. Trust me, I would have kept the NC700x for as long as possible if I could.
