vinay
Already a few weeks ago I installed my navigation device on the handlebar, but back then I already knew I eventually wanted it to be above my dashboard so that I could see it without tipping my head down.
![signal-2024-06-15-201843_002.jpeg signal-2024-06-15-201843_002.jpeg](https://www.nc700-forum.com/data/attachments/107/107749-7cd991a8ea0ada213303a011bec08888.jpg)
Last Thursday I installed this Givi accessory support (FB1146 for the NC750X from 2016 to 2020) which is mounted between the windscreen and the spoiler in front of the dashboard. The device uses Apple Carplay which can use several apps. OSMand, Gaia and of course the Apple Maps app all work, but I'm now using an app from TomTom, a local navigation device company. It can work without cell broadcast like OSMand and Gaia do, but it can also divert your route if there are delays, roadblocks etc on the otherwise fastest route. I this image it may appear to be mounted quite high, but from my perspective when driving it appears just above the display so that both are clearly visible. What it does to the wind (shield me or make matters worse) I don't know really. It was quite windy today so I was feeling it anyway.
![signal-2024-06-15-201843_003.jpeg signal-2024-06-15-201843_003.jpeg](https://www.nc700-forum.com/data/attachments/107/107750-00e07ebd15985eaaf383826959ed5028.jpg)
The power cable branches from the accessory harness and travels along underneath that left fairing. In my case I made it pop out between that fairing which holds the direction indicator and that big flexible horseshoe-shaped fairing. I then made it disappear to the other side of the spoiler.
![signal-2024-06-15-201930_002.jpeg signal-2024-06-15-201930_002.jpeg](https://www.nc700-forum.com/data/attachments/107/107751-bb67bf469bfc5cc4238417ba3709399e.jpg)
Over there I channeled it just left of the Givi mount so that it doesn't dangle in that center channel. There sure must be ways to do this even prettier but I'm quite happy the way it is now. If the way the cable exits between those plastic shells turns out to be annoying when removing and reinstalling the plastic covers I might reconsider and come up with something else. But for now I'm quite happy the way it is.
![signal-2024-06-15-201843_004.jpeg signal-2024-06-15-201843_004.jpeg](https://www.nc700-forum.com/data/attachments/107/107752-6f91e8b95439e947efa3d88578514393.jpg)
So yeah it may very well be catching some air but the ram mount used does keep it nice and steady. This one has a 5" screen. They also have one with a 7" screen which may seem cool but would probably have been a bit much. It is now about right above my handlebar so easy enough to see and easy enough to operate when needed.
