skeedaddle
Ok...so you guys have some really great tricks. Let's here em. I want to install a rear hugger which requires removing the rear brake line bracket on the swing arm. One of the bolts in the bracket is stripped and will not come out. It seems the female ferrule the bolt threads into is spinning with the bolt when I try and loosen it. Ive tried to pry up on the bolt while I turn it... but no luck. Any ideas how to remove it?
