misterk
Ok, I added these lights, they are the Cree 18w lights (18w for each light). Since they are drawing 36w (I assume about 3amps), is that too heavy a load to wire into the Oem aux. harness (which I have). I want to wire it to the high beam switch. The one with the 3 wires one being the blue.
So do I take the black wire on the lights to the negative wire on harness (which color?), and the red wire on the lights to the blue wire?
Thank you for your help.
