showkey
Totally normal and it is not drag through the clutch.......but rather oil drag of the gears in the trans dragging through the oil. NOT that it really matters............the reason is:
In neutral and with the clutch out the clutch and mainshaft and all the gears are one whole unit no slip no drag. The counter shaft is direct connection to the rear wheel with it gears on the shaft. The oil drag between the gears rotating on the shafts is what "powering" or causing the rear wheel to rotate.
If the bike were to creep forward when in gear with the clutch handle pulled in then the cause then would be clutch drag.
