AsureDawn
I've gotten an Aprilia Tuono shock for my NC, and was reading the NC's service manual to get an idea of what replacing the shock would entail, and I got thinking... a few were worried about whether it'd be fine using this particular shock because of the bushing, but it appears the OEM shock uses one too. There's instructions on replacing the bearing on the bottom, but no mention of the one on top (and it mentions checking the bushing for damage, pointing at the top joint), and bike bandit only lists one part, the needle bearing for the lower joint, and the diagram doesn't point at both (only the bottom).
So (tl;dr), does the top joint, in fact, have a needle bearing, or is it a bush?
