W
wildeone
I don't know how you guys riding but my shifter is notchy, clunky and not smooth as I would like.
Especially from 1st to 2nd and 2nd to 3rd.
DCT or manual? I know the DCT clunks into 2nd if you use sport shifting, in drive mode it does relatively fine though, higher rpm switches probably causes the clunk i think.
The NC700X has a "Constant Mesh" transmission!! There are no Syncronizers like those found in most Automobile Transmissions!! Smooth "Clunkless" shifts are possible but not every time even with the most experienced riders!! The Constant Mesh transmission will (almost) always clunk when shifting from neutral to First when the engine is running!!
If your clutch completely disengages when in gear & sitting still, , & engages smoothly & doesn't slip when moving & with throttle applied, , , then you probably have a properly operating clutch!!
The most common transmission killer are harsh shifts like kicking/stomping on the shift lever!! The force from those harsh shifts transmit directly to the shift forks, , which determines gear engagement!! Not enough engagement can result in damage to the gears & symptoms like jumping out of gear!!
Newer transmissions have devices that help prevent damage from harsh shifts but those won't help the Clunkiness!!
Practice smooth shifts is the best solution!! ��
Once you've checked & adjusted external things as suggested by others already, my suggestion is to try some different styles for a while and see what sort of effect it has for you. I have ~26,000 miles on mine (manual shift, if that's not already apparent), and it has shifted quite smoothly for me since it had perhaps a couple thousand miles on it, unless I lose my 'rhythm.'![]()
I enjoy the clunk.
