Pricing Revealed for Triumph Speed 400 / Scrambler 400 X
We finally have the pricing for Triumph’s new Speed 400 and Scrambler 400 X!
Recall, that Triumph revealed this middleweight scrambler/roadster duo back in late June with the notice that the machines would be hitting our dealerships by January 2024. Until this week, we knew the Speed 400 to be rated at around Rs. 2,33,000 in India; that’s roughly $2,800 USD, a far cry from what the bike’s price would be in America.
A view of Triumph's Speed 400. Media provided by Triumph.
A view of Triumph’s Speed 400. Media provided by Triumph.
The Speed 400 was also going to be up against budget-friendly bikes like Royal Enfield’s wildly successful Hunter 350, priced at a starting rate of $3,999 USD; for the Scrambler 400 X, competitors included Royal Enfield’s iconic Himalayan, currently available for $5,449 USD – tough contenders, making the guessing game for the 400 siblings’ prices a tad more lively.
Now, the guessing games are over; Spurgeon Dunbar at RevZilla lists the following rates ‘n’ perks (MSRP) for Triumph’s beginner-friendly Speed 400 and Scrambler 400 X:
Triumph Speed 400​
$4,995 USD
Triumph Scrambler 400 X​
$5,595 USD
A view of Triumph's Scrambler 400 X. Media provided by Triumph.
A view of Triumph’s Scrambler 400 X. Media provided by Triumph.
2024 TRIUMPH SPEED 4002024 TRIUMPH SCRAMBLER 400 X
Engine398cc, liquid-cooled, four-valve, single-cylinder
Transmission,Six-speed, chain
Claimed horsepower39.5hp @ 8,000rpm
Claimed torque27.7ft-lbs @ 6,500rpm
FrameTubular steel, bolt-on subframe
Front suspension43 mm fork; 5.51 inches (140mm) of travel43 mm fork; 5.91 inches (150mm) of travel
Rear suspensionMonoshock; 5.11 (130mm) of travelMonoshock; 5.91 inches (150mm) of travel
Front brakeRadial-mounted four-piston caliper, 300mm (11.8”) disc with ABSRadial-mounted four-piston caliper, 320mm (12.6”) disc with ABS
Rear brakeFloating caliper, 230mm (9.1”) disc with ABS
Rake, trail24.6 degrees, 4.01” (102mm)23.2 degrees, 4.25” (108mm)
Wheelbase54.21” (1,377mm)55.82” (1,418mm)
Seat height31.10” (790mm) unladen32.87” (835mm) unladen
Fuel capacity3.43 gallons (13 liters)
TiresMetzeler Sportec M9RR 110/70R17 front, 150/60R17 rearMetzeler Karoo Street 100/90R19 front, 140/80R17 rear
Claimed weight374.78lbs (17kg) wet394.63lbs (179 kg) wet
Warranty24 months
More infotriumphmotorcycles.com
final drive
What do you like about Triumph’s Speed 400 and Scrambler 400 X?
*Media provided by Triumph*​
The post Pricing Revealed for Triumph Speed 400 / Scrambler 400 X appeared first on webBikeWorld.
