StratTuner
This morning's engineering project is to connect a piece of aluminum flat bar from the rear of the pillion peg to the license plate frame assembly as in this photo. (see where the yellow line is).
The flat bar will bolt on to the rear of the pillion peg and on to the existing bolt that holds in the license plate frame.
I plan to buy a longer bolt for the tail assembly to accomodate the thickness of the flat bar.
Bolting to the opposite side of the rear pegs should be easy since there are pre-fitted, machined, bolt holes back there already.
What size bolt goes in those unused holes on the inside of the rear pegs? Anyone know?
My plan now is just to go to the hardware store and by 1/2" long 10, 11, 12, 13, 14, and 15mm metric bolts. I figure one of them will fit.... and then I'll know.
What is the purpose? I plan to strap cylindrical "duffle" bags to the rear hand rails to use as saddle bags. Each bag will hang down off the side rear hand rails.
The handrails will bear all the weight, the flat bar is just there to keep the bags away from the wheel.
I'm hoping it will be fairly simple to take on and off and keep the bags out of the rear wheel.
