Jguarfn28
I changed my tires at home a couple of months ago. I have Harbor Freight Torque wrenches that I have some doubts about. Mostly because they never seem to pop at the torque setting and I don't want to replace a broken bolt. At any rate, I was backing Sylvia into the garage and heard a scraping noise that made me wonder where it was coming from. When I bent over and looked at the front axle, I did a double take. The front axle bolt was sticking out 2" from the fork base. I had tightened them where "I" thought was really tight, obviously, "I" was mistaken.
Broke out my Craftsman Beam Torque Wrench and checked the shop manual this time and locked it down at 74lbs. Used the HF 3/8's in. for the lock bolt and hit 22lbs, I hope. I had put a couple of thousand miles on the 705 Shinko's and they seem to be no worse for wear. Glad I am still around to post this encouragement to check your nuts and bolts. Especially your nuts.......
