golfbug412
Can anyone tell me the recommended tire pressure?...I can't locate it in the owners manual
I wonder is it different for cars? When learning to take care of my cars I was always told to ignore the sidewall writing and use the pressure recommended on the vehicle label, regardless of what tire I was using. The sidewall writing gives a max psi for the tire but not the ideal psi for the vehicle/tire combo. Correct me if I'm wrong, of course.
I have a KTM which weighs similarly to the Honda. Its recommended tyre pressures are 34 PSI front and back. I believe 42 psi for a rear tyre solo, is way too much, and does not allow the tyre to heat up properly. I have experimented. I run the front at recommended 36psi and the rear at about 38/39 psi solo. That does it for me.
